brake reservoir - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 03-10-2013, 03:24 PM Thread Starter
Talking brake reservoir
Does anyone know a good solution for the brake reservoir on drag bars? The problem i'm having now is that it is on too much of an angle to keep a steady flow of brake fluid. the handle bars are straight across.
jtaylor is offline
post #2 of 7 (permalink) Old 03-17-2013, 10:25 PM
Mntsnow's Avatar
what diameter are your drag bars? There is a few options out there in the aftermarket depending on the size of bars.
- Mntsnow -
1988 VN750 - Fixing up for my son!
Mntsnow is offline
post #3 of 7 (permalink) Old 03-18-2013, 12:38 PM
soltz's Avatar
Question
If the problem is your hitting the triple clamp add a couple inches to each side of bar to allow clearence.
soltz is offline
post #4 of 7 (permalink) Old 03-18-2013, 07:28 PM
...didnt you post this in another thread already ? Couldda sworn I replied.
post #5 of 7 (permalink) Old 04-19-2013, 11:11 AM
i'm interested in the solution for this as well, I have drag bars on mine and to cheap to buy the stock ones
92 Stealth
89 Trans Am
67 Camaro
91 suburban v2500
yevgenievich is offline
post #6 of 7 (permalink) Old 04-19-2013, 08:29 PM
I seem to recall a similar question being asked recently too Wolfie, but it musta been someone else. (note that I am being influenced by your purposely casual spelling. )
So far jtaylor has only made 2 posts, the question above and his intro on the newbie check in:
https://www.vn750.com/forum/showthread.php?t=24219
post #7 of 7 (permalink) Old 04-19-2013, 08:44 PM
Yeah, well even though I know better, I like caual spelling because I talk the same way usually...
Mounting on drag bars....cannot be done properly unless you modify the mount. The top of the res need to be level or close to it to retain a proper flow. My suggestion would be to look for a res off of another Jap bike that has bars similar to drag bars and the res mounts level. Yould need to change the clutch mount then also to make the levers match.
If you have a friend in a machine shop, a shim could be made to make it ride properly, but you'd need longer bolts and could end up with an ugly gap.
Id check other Jap MCs before I did anything. More than likely the banjo bolts are interchangable/same. Mebbe even off of another Kawi, like one of the KZ models.
Tags
brake , brake reservoir , front brake , handlebars
