To SLIME, or not to SLIME ? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 12 (permalink) Old 09-07-2006, 04:47 PM Thread Starter
Gnarly Jokester
norsseman's Avatar
Location: Southwest of Ruby Ridge, Geiger Heights, Washington, USA.
Question To SLIME, or not to SLIME ?
Read at J&P cycles that Slime is not recommended for Aluminum Rims,
wondering what our VN750 Rims are made out of ?
Apparently Slime causes corrosion with Aluminum Rims.
"When the sun's comin' up,
I got cakes on the griddle.
Life ain't nothin' but a funny funny riddle,
Thank God I'm a Country Boy!"
norsseman is offline
post #2 of 12 (permalink) Old 09-07-2006, 05:27 PM
Uber Member
we have aluminum that is annodized
'04 Vn750
Currently Installed
nat'l cycle deflector shield
R/R relo
TOC ACCT's
Mez's 110-FRT 170/80-Rear
Hizzo3 is offline
post #3 of 12 (permalink) Old 09-07-2006, 06:17 PM
fergy's Avatar
No!! Don't use slime!
I and a whole gob of others use "Ride-On", which is guaranteed not to damage or corrode rims and will balance your tires and make them wear longer and other stuff. Go to their website and read about it. Good stuff! I've read reviews that weren't on their own website about it and everyone says it's great stuff. Washes off with soap and water... Won't piss off your local tire guy...
http://www.ride-on.com/
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #4 of 12 (permalink) Old 09-07-2006, 08:55 PM
Search Goddess
Dianna's Avatar
What Fergy said!
No to Slime!!
Yes to Ride-On!
My tire guy won't touch a slimed tire.
Dianna
Conway, AR
Patriot Guard Rider
2000 VN750 Sere (Serendipity)
1990 GL1500 (Ole Blue)
VROC # 11628 / 25000-H
OKVROC # 18 (H)
TNVROC # 45 (H)
Dianna is offline
post #5 of 12 (permalink) Old 09-07-2006, 11:34 PM Thread Starter
Gnarly Jokester
norsseman's Avatar
Read up on Ride-On and it sounds and looks good, will check out a few other
alternatives to the famous Slime. Plan on doing some Adventure Riding in Old
Mexico when I totally Retire and will be using Ride-On for sure down south of the Border.
Flat's are common South of Gringo Pass. Ahh that's good Cervesa on a hot and dusty day.
post #6 of 12 (permalink) Old 09-08-2006, 03:13 AM
Originally Posted by fergy
...and will balance your tires...
Do you have any idea how well this stuff balances them ?
If I do my own tire changes on the streetbike this would be a big help.
Oh yeah, like they said....
DON'T SLIME THEM !!!
post #7 of 12 (permalink) Old 09-08-2006, 10:58 AM
Uber Member
well their web site says it does.... and in theory it would work really well. But it must be roughly balanced first.
Also side note, if you match the dot on the tire poperly, you rarely need to do additional balancing, and if you do its minimal. there is a post about all u need to know on here somewhere with a vid too
'04 Vn750
Currently Installed
R/R relo
TOC ACCT's
Hizzo3 is offline
post #8 of 12 (permalink) Old 09-11-2006, 10:24 AM
fergy's Avatar
The ride-on does have a balancing effect. They claim your tires will wear longer and more evenly. I do know that on my first ride after installing the stuff, there was a slight feeling of floating on air. It was the weirdest feeling. It was a subtle change, but definitely noticable.
Fergy
2002 VN1500 Classic
SEAFOAM JUNKIE!
fergy is offline
post #9 of 12 (permalink) Old 09-11-2006, 04:46 PM
Once Banned
cegodsey's Avatar
I've had that happen in my car. You probably pinched a butt nerve.
2000 A16
Drilled baffles
$65 leather saddle bags
Kuryaken grips
relocated R/R
de-badged
25,000+ original owner miles
cegodsey is offline
post #10 of 12 (permalink) Old 09-11-2006, 05:19 PM
tankist's Avatar
Send a message via Skype™ to tankist
when you put this stuff in it just piles up near the valve stem area. i would think it takes at least couple of miles before it spreads (under centrifugal force) evenly in a tire. during this time you have very unbalanced wheel hence the floating.
how dence is this stuff? obviously the denser it is the longer it would take to spread. i would think it should be something like honey to work.
cegodsey, doesn't it collect on the bottom of a tire if you don't drive/ride for some time? cause then the wheel would be unbalanced again.
http://agrasyuk.googlepages.com/home
Anton Grasyuk
Wheeling, IL
tankist is offline
