Front/Rear Wheel Bearing Inner Diameter? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 10-05-2012, 06:16 PM Thread Starter
Hey all,
I'm going to replace my bearings when I install these 880s, but I want to make sure the inner-diameter of the bearings is 20mm, or something different?
I did some searching and didn't see anything, so apologizes if I missed it. Thanks!
post #2 of 4 (permalink) Old 10-05-2012, 07:18 PM
the bore is 17mm, ODIA= 47, Width= 14mm, the bearing part number is 6303UUC
post #3 of 4 (permalink) Old 10-05-2012, 11:59 PM Thread Starter
Cheers slim. I knew somebody would know!
post #4 of 4 (permalink) Old 10-06-2012, 12:43 AM
Its not that I know.. its that I know where to find bearing information... I used to work in several Automotive Parts Stores and picked up how to read bearing information. I take the bearing part numbers and plug them into my book and it tells me all about the bearing.
the rear wheel bearing brakes down like this...
6303UUC
First we know its a Ball Bearing Type bearing
so we would search for a 6000 series ball bearing
the spec book then lists the bearing in Numeric-Alphebetical order, so then find the 6300's
then the 6303
which gives you the specs I showed earlier
Then the letters tell you that it is a sealed type bearing, type and style of seal, and that it is not recommended for pressed in applications.
