Tire Sizes - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 16 (permalink) Old 09-02-2012, 04:27 PM Thread Starter
Question Tire Sizes
so i'm needing new tires. heard great things about the shinkos. problem is that they dont make one in the same size that i have right now (150/90-15), but they do make a 150/80-15. that is a shorter tire than i have right now, and i actually want to go taller. at 70mph i'm right around 5K rpm, and i'd like to drop that down a little bit. anyone have any suggestions?
- 1998 Vulcan 750
- Black with red
- MCCT conversion
- Pick up coil mod
- Stereo with 3.5 inch speakers
- Sylvania ridiculously bright headlight
- Westco maintenance free battery
- Vance & Hines slash cut pipes
- Custom turn signal bracket
- Arrowhead universal turn signals (rear only)
- Kuryakyn longhorn offset highway pegs
- Suzuki Savage 650 rear shocks (2 inches shorter)
- Lowered front 1.5 inches
drfraser is offline
post #2 of 16 (permalink) Old 09-02-2012, 05:00 PM
Do they have a 170/80? That should work for you too.
MCCT Mod
Pickup Mod
12 Volt Receptacle Mod
Memphis Shades Santa Cruz
Homemade Luggage Rack
NGK Iridium IX Spark Plugs
Harley Sportster Exhausts
Rotating/Flashing Tail Lights
170/80 Michelin Commander II
Saddlemen Highwayman Slant Jumbo Saddlebags
Bought 09/10 12.2k miles - 04/12 33.4k miles
CW-4 is offline
post #3 of 16 (permalink) Old 09-02-2012, 05:09 PM Thread Starter
would the width make a difference? i've ridden a bike with a really wide back tire and it didn't handle for **** lol
- 1998 Vulcan 750
- Black with red
- MCCT conversion
- Pick up coil mod
drfraser is offline
post #4 of 16 (permalink) Old 09-02-2012, 08:24 PM
I'm running 170/80 and haven't noticed any problems in handling? How about some of you other guys that are running 170's? Any problems?
Was a tight fit getting it past the final drive, but not too bad. I put mine on after letting out most of the air pressure so the sidewall would go past the final drive easier.
MCCT Mod
Pickup Mod
CW-4 is offline
post #5 of 16 (permalink) Old 09-02-2012, 11:08 PM
Deviate's Avatar
Ditto for me. No issues with the 170/80 Shinko for me.
Deviate is offline
post #6 of 16 (permalink) Old 09-03-2012, 11:02 PM
mine is on its way to me so i cant tell you yet but i havent heard a bad thing about the shinko's on here yet
mine cost 86.99 plus about 6.99 shipping from motorcycle-superstore.com
post #7 of 16 (permalink) Old 09-07-2012, 02:21 PM
just got my shinko 170/80/15 today and off the rim it looks smaller than the stock size but on the rim it looks almost exactly the same
post #8 of 16 (permalink) Old 09-08-2012, 08:48 AM
JM2001's Avatar
Same here. I'll stay with the 170/80/15 size.
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #9 of 16 (permalink) Old 09-12-2012, 08:10 AM
The 170/80 shinko gives me the same, 5k @ 70mph.
4/12/12 1st bike ever! 95 VN 750 13k
New plug wires
Iridiums
Coil relay mod
MCCT mod
EPA stuff removed
Rear signals shaved
Shinko 170-110 oversized tourmaster tires
Splines lubed
Front signals relocated.
skyboxer is offline
post #10 of 16 (permalink) Old 10-03-2012, 11:49 PM
'03 VN750 "Rosie"
bstew7890's Avatar
I just ordered a Shinko 170/80 at cycle gear. It cost a few bucks more but I'll save some on shipping and on mounting. I then went on eBay and ordered brake shoes so I can change them as we'll as the spline lube in one shot.
'03 VN750 "Rosie"
Purchased in June 15, 2010
Lubed Splines
Lubed and Adjusted Clutch Cable, Throttle Cables.
Relocated Voltage Regulator
Brakes Bled
Luggage Rack
Lazy Rider Bag
Leather Saddle Bags
Legitimate Title!! (finally!) Aug 30, 2010
New AGM Interstate Battery Sept 15, 2012
2008 Hyosung GV250 (sold!)
bstew7890 is offline
