no brake light - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 08-19-2012, 12:54 PM Thread Starter
no brake light
hello, my 750 has a issue with brakes i do not have brake light when i use front brake but i do when back brake is used. i checked wires they are hooked up i tried another switch same thing, any ideas?
vulcan98 is offline
post #2 of 10 (permalink) Old 08-19-2012, 05:52 PM
1. Still a bad electrical connection.
2. Replacement switch also defective.
3. Bad connection with another harness connector (under the tank?) ???
Try removing connector from from brake light switch, with key on, short the 2 contacts together. Results will isolate or eliminate #1 and #2 above.
hope this helps
WilliamTech
post #3 of 10 (permalink) Old 08-19-2012, 06:31 PM Thread Starter
will try that , thanks for reply
vulcan98 is offline
post #4 of 10 (permalink) Old 08-19-2012, 07:23 PM Thread Starter
k, i took tank off and jumped yellow wire and blue wire brake light came on, now where do i go? i looked in manual couldnt find anything bout front brake switch except that it isnt adjustable and truthfully electrical is my worst area
vulcan98 is offline
post #5 of 10 (permalink) Old 08-19-2012, 07:59 PM
pull the two wires off of the brake master cylinder and jump those two wires to see if your brake lights come on... o need to pull the tank.
post #6 of 10 (permalink) Old 08-19-2012, 08:01 PM Thread Starter
aright found broke wire , fixed it and now got brake light front and back but lost turn signals.
vulcan98 is offline
post #7 of 10 (permalink) Old 08-19-2012, 09:52 PM
At this point, I suggest taking off seat and tank, and checking EVERY wire and connector ya got then...do a visible first, and clean any connectors adding a lil dilectric grease..take off the headlight lense too...connectors in there...
post #8 of 10 (permalink) Old 08-19-2012, 09:58 PM Thread Starter
k will try that , thanks for input
vulcan98 is offline
post #9 of 10 (permalink) Old 08-19-2012, 11:16 PM
ExpectationLESS's Avatar
i have tryed a repair on the harness connector under the tank several times. i think i am just going to make my own connection for the brake light wires.
ExpectationLESS is offline
post #10 of 10 (permalink) Old 08-20-2012, 01:03 PM
Make sure you solder all yer homemade connections too...
