Front Axle Nut Gone - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 08-09-2012, 06:06 PM Thread Starter
Exclamation Front Axle Nut Gone
So after my ride today I decided I was going to clean my rims on my front tire. When I was down there I noticed that my front axle nut is gone! I dont know how it randomly dissapeared but I do believe I need to put one on. I was wondering has this ever happened to anyone else? Also will a regular 14mm nut work from like Lowes?
2002 Vulcan 750
-Riding is living-
mhdrummer6 is offline
post #2 of 8 (permalink) Old 08-09-2012, 06:57 PM
Was it the nut that is supposed to have a cotter pin on it? If so, you'll want one that is cut for that, so you can replaced the cotter pin and ensure it doesn't back out again.
post #3 of 8 (permalink) Old 08-11-2012, 12:07 AM
that kind of nut is called a crown or king nut
post #4 of 8 (permalink) Old 08-11-2012, 08:50 AM
Deviate's Avatar
My front axle doesn't have a castle nut with cotter pin. Only the rear does.
Deviate is offline
post #5 of 8 (permalink) Old 08-11-2012, 02:16 PM
Patriot Guard Rider
The DEUCE's Avatar
The fronts do not come with a castle nut. You are fine.
VN750 #9300 & VROC #33453
The DEUCE is offline
post #6 of 8 (permalink) Old 08-11-2012, 11:36 PM
You can get the nut at yer closest Harley shop (note, I didnt say dealer)...same forks...same axle....if a Kawi shop is closer, go there...all the same...and if ya get a nut from HomeDecoy, make sure its the proper hardness....thats them lil numbers and slashes on the sides...when ya put the new on, put a dab of Loctite on, or take a point punch, and peen the axle threads a lil just outside of the nut...
post #7 of 8 (permalink) Old 08-12-2012, 01:19 AM
I thought the same thing after I got my bike. If you look at the bike from the front, the bit of axle on the left side with the hole is to help you get leverage to unscrew the axle. No castle nut needed.
post #8 of 8 (permalink) Old 08-17-2012, 01:43 AM
The front axle nut is a locking type. I would replace it with a stock part. The axle still can't come out, as it is clamped on the other side. But I wouldn't want no Home Depot nut on my axle.
suitcasejefferson is offline
Tags
front axle nut
