A Little Help With Calipers? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 08-02-2012, 08:55 PM Thread Starter
Crap, I WAS in 5th gear.
I need to replace my pads and lube the slides tonight. Anybody know if the rubber end on the slides pushes back through the caliper housing? That's all I can gather from looking at parts diagrams and Clymers.
Kelly2001 is offline
post #2 of 3 (permalink) Old 08-03-2012, 12:40 AM
OldBikeNewRider's Avatar
I don"t get your queston but there are plenty of you tube vidoes on motorcycle brakes that could help you out.
1986 VN 750
20,000 miles
Replaced Stock Turn signals
Starter Clutch
NGK plugs
MT66 Pirelli's
Seafoam
OldBikeNewRider is offline
post #3 of 3 (permalink) Old 08-03-2012, 04:16 AM
Ndr
If I Understand you correctly... NO.
The rubber pieces stay pretty much where they are.
Just slide the two pieces of the caliper apart. Might be a little tough if they are all grimed up. One note, you'll need to get the pads out of the caliper before the two pieces come completely apart. You'll need to open up the caliper a bit to get the room to be able to tilt the pads out.
Ndr is offline
