Parking lot hit - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 07-26-2012, 08:01 PM Thread Starter
'03 VN750 "Rosie"
bstew7890's Avatar
Parking lot hit
I rode Rosie to a work meeting today and when I got out I almost had an accident in the parking lot because with the bars straight she turned left! I pulled over and looked and the front wheel is definitely no longer aligned to the bars. There's no sign of damage beyond that, no scratches or dents, she rides straight and smooth as long as I don't try to straighten the bars while moving. I'm thinking of loosening the fork brace and trying to straighten it back out. Will it work? anyone done this before?
'03 VN750 "Rosie"
Purchased in June 15, 2010
Lubed Splines
Lubed and Adjusted Clutch Cable, Throttle Cables.
Relocated Voltage Regulator
Brakes Bled
Luggage Rack
Lazy Rider Bag
Leather Saddle Bags
Legitimate Title!! (finally!) Aug 30, 2010
New AGM Interstate Battery Sept 15, 2012
2008 Hyosung GV250 (sold!)
bstew7890 is offline
post #2 of 11 (permalink) Old 07-26-2012, 08:10 PM
Its been done and will work as long as nothing is bent. Good luck and good job staying in control.
post #3 of 11 (permalink) Old 07-26-2012, 08:34 PM
make sure to use a torque wrench on all the tripple tree bolts....
post #4 of 11 (permalink) Old 07-28-2012, 01:02 AM Thread Starter
'03 VN750 "Rosie"
bstew7890's Avatar
It worked. I loosened the fork brace on both sides, then the brace on top f the triple tree. The tubes wanted to drop down at that point so I pushed them up and tightened the top with the help of a second person. Then I stood in front and he'd the whel with my knees and pushed the handlebars with my hands to straighten it, then tightened the lower brace again. Took it around the block and it feels much straighter now. I think I stripped the fork tube caps though.
'03 VN750 "Rosie"
Lubed Splines
Brakes Bled
Luggage Rack
Lazy Rider Bag
Leather Saddle Bags
post #5 of 11 (permalink) Old 07-28-2012, 01:44 AM
no mention of a torque wrench...... ?
WilliamTech
post #6 of 11 (permalink) Old 07-28-2012, 03:09 PM
Thet dint actually strip, but because are slotted plastic, when overtightened, the slots widen and dont go back....easy fix is to slightly coat the bolthead/or schrader valve threads with a little silicone seal, then replace until they just touch...or if you have cement for plastic models, dab some on the threads of the cap, with a lil light oil on the bolt threads...replace, and the glue will mold new threads....
post #7 of 11 (permalink) Old 07-30-2012, 01:56 AM Thread Starter
'03 VN750 "Rosie"
bstew7890's Avatar
WilliamTech
I couldn't find torque values for those bolts in my Clymers book so I tightened them by feel to the approximate tightness I found them. If anyone has the values please share and I will set the torque accordingly.
'03 VN750 "Rosie"
Lubed Splines
Brakes Bled
Luggage Rack
Lazy Rider Bag
Leather Saddle Bags
post #8 of 11 (permalink) Old 07-30-2012, 01:58 AM Thread Starter
'03 VN750 "Rosie"
bstew7890's Avatar
I used some clear bathtub caulk. I think it's the same stuff I used on the swingarm pivot caps.
'03 VN750 "Rosie"
Lubed Splines
Brakes Bled
Luggage Rack
Lazy Rider Bag
Leather Saddle Bags
post #9 of 11 (permalink) Old 07-30-2012, 09:09 PM
...that'll work...I mean, unless ya have air valves, yer rarely gonna remove anyway...
Torque specs are : 14.5 ft/lbs for the top bolts
18 ft/lbs for the lowers
29 ft/lbs on the main center
Diagram and specs are on 13-2 "Steering" , btw...bet you were lookin under forks...
post #10 of 11 (permalink) Old 07-31-2012, 03:13 AM
X2 Wolfie.
TSmith68 is offline
