changing front tire - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 06-26-2012, 09:27 AM Thread Starter
photobuff4u's Avatar
changing front tire
Hi all...wondering what is the best method to get front rim off my vulcan. I realize that tire replacement best accomplished by a shop set up to do tire changes, but I thought I would change the tire myself.....what is preferred method to support bike for the process....thanks.....I know I'll get the right answers from the group as always......
photobuff4u is offline
post #2 of 6 (permalink) Old 06-26-2012, 09:53 AM
Most folks just use a jack to hold the front end up (after putting the bike on the centerstand) I used a large brick and a piece if wood.... Anything solid that won't slip out is fine.
Loosen you axle nut first btw......
post #3 of 6 (permalink) Old 06-26-2012, 01:59 PM Thread Starter
tnx as always...you guys are the best.....waiting for the rain to stop.....
post #4 of 6 (permalink) Old 06-26-2012, 03:18 PM
Model A Guy
Jeff Barnes's Avatar
Rim off bike
I have a floor jack and used it to support the front of engine by the starter, with a piece of wood between jack and engine. I have never trusted a jack by itself to do any work on a vehicle, and use jack stands. With the bike I used an old toolbox across and under the front forks while the wheel is off in case it was to leak off and maybe cause the v-stand to fold up. Glad I did as my wheel was off for a full day while mounting tires. The tool box had some weight on it when reinstalling wheel and the engine had to be jacked back up a bit. You also have to remove one or the other brake calipers so the rim will pass through the forks. That about all there is to it.
Jeff Barnes is offline
post #5 of 6 (permalink) Old 06-26-2012, 07:06 PM Thread Starter
thanks so much...waiting for the rain to stop, then maybe tackle it...take care....
post #6 of 6 (permalink) Old 07-01-2012, 04:08 PM
i have a handy dandy wotorcycle jack that works wonders
