Front brake lever not right - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 06-15-2012, 05:20 PM Thread Starter
DACataldo's Avatar
Hi all, didn't find anything on this subject so I have to ask. When I press my front brake lever in to stop the bike, it "kinda" sticks a little and when I give extra pressure, the lever "unsticks" and pulls back further than I want and the front brakes goes on harder than I intend. I then have to let up and "speed-press" on the lever to get the bike to stop at the rate I want. This is new to me, so I was curious - Is this a WD-40 fix or fluid change? Or????
Dave
2005 Vulcan 750
Odometer @ October, 2019: 14,200
Purchased May, 2011 @ 2,172
Splines lubed @ 2,962 (were in good shape)
Küryakyn Daily Tour Bag
SS-28 Slipstreamer Smoke
DACataldo is offline
post #2 of 9 (permalink) Old 06-15-2012, 05:28 PM
romeobravo172
romeobravo172's Avatar
Sounds like your master cylinder plunger is sticking, or you have a caliper piston sticking, not moving freely back and forth.
romeobravo172 is offline
post #3 of 9 (permalink) Old 06-15-2012, 09:12 PM
...suggest a fluid change would be a great place to start. I had problem with the lever not releasing completely....just enough to where the brake light stayed on. Drained / cleaned MC (tiny pin hole clogged) new fluid, works like new !
Hope this helps
WilliamTech
post #4 of 9 (permalink) Old 06-15-2012, 10:25 PM
x2 on a fluid change and cleaning.
MCCT Mod
Pickup Mod
12 Volt Receptacle Mod
Memphis Shades Santa Cruz
Homemade Luggage Rack
NGK Iridium IX Spark Plugs
Harley Sportster Exhausts
Rotating/Flashing Tail Lights
170/80 Michelin Commander II
Saddlemen Highwayman Slant Jumbo Saddlebags
Bought 09/10 12.2k miles - 04/12 33.4k miles
CW-4 is offline
post #5 of 9 (permalink) Old 06-15-2012, 10:32 PM
Check out my post called Front Brakes Locked Up. It sounds like thats where your headed.
WuggyBump is offline
post #6 of 9 (permalink) Old 06-15-2012, 10:42 PM
...could also be as simple as road crud in between the actual lever and mount as well...I had it happen to a '68 Sportster of mine's clutch after riding 9 hrs in rain, sleet and snow...
post #7 of 9 (permalink) Old 06-16-2012, 11:18 PM Thread Starter
DACataldo's Avatar
Thank you all for the input and quality ideas! I'm getting right on it......
Dave
2005 Vulcan 750
post #8 of 9 (permalink) Old 07-04-2012, 03:04 PM
Crap, I WAS in 5th gear.
I had the same issue and bought a rebuild kit. I have also had a singing noise for the past 10,000 miles at slow speed. However, when I changed out my front tire, the issues magically resolved. I can only conclude that a caliper, pad or piston was stuck. My recommendation after a fluid flush, is to remove the calipers and push the piston in slightly to possibly unstick them. Check the slide pins and clean/lubricate. Make sure the pads are free in their slots.
Kelly2001 is offline
post #9 of 9 (permalink) Old 07-06-2012, 06:20 PM Thread Starter
DACataldo's Avatar
Originally Posted by Kelly2001 View Post
..... My recommendation after a fluid flush, is to remove the calipers and push the piston in slightly to possibly unstick them. Check the slide pins and clean/lubricate. Make sure the pads are free in their slots.
Aha - as soon as I finally do get to this job (been avoiding the sweat-house outside) this will be something I'll check. Thank you.
Dave
2005 Vulcan 750
