1500 front end - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 05-14-2012, 11:41 AM Thread Starter
kctrigger's Avatar
1500 front end
well i completly redid the front end still waiting on an axel before i can get it back out on the road and I still gotta wire the signals up but all and all its coming together nicely
ID:	4519   Click image for larger version
ID:	4520   Click image for larger version
03 Vulcan 750 Bobber
ADDED -
Straight Slash-Cut Pipes
ISO Gribs
Heat Shields
Grill
Arrow Chrome Turn Signals on back
Harley Signals on front
Side Mount License Plate
Bobber Headlight
Mini Speedo
Solo Seat
VN 1500 Front End
Switched out Ignition and Relocated
Ear Shave
kctrigger is offline
post #2 of 7 (permalink) Old 05-15-2012, 06:42 PM
Looks good, I have been wanting to do this to mine. How much longer than stock are the vn1500 forks?
post #3 of 7 (permalink) Old 05-16-2012, 12:14 AM
Daily rider
ksmnet's Avatar
Actually, unless the camera angle is distorting the picture, it looks like the front end might actually be lower than stock.
So, when you are done with this bike, will you call it a 7509001500?
2017 Indian Roadmaster (current ride)
2003 VN1600A (Traded August 2017 to #1 son for a Bushmaster AR)
2001 VN750 bought 4/19/08 w/2309 miles(Sold April 2010 with just over 12,000 miles)
VROC #33035
__________________________________________________ ________________
Just when I thought I was winning the rat race, somebody moved the finish line!
ksmnet is offline
post #4 of 7 (permalink) Old 05-22-2012, 05:34 PM Thread Starter
kctrigger's Avatar
I haven't really put em up together to find out i think they are a bit shorter though the bike is on the center stand so i'm hopin that the bike levels out similar to like it was before, the axle i ordered was wrong but i'm not out much since the guys i got the forks from didn't have on there what style 1500 they came off i'm having to track down what axle fits. Will let ya'll know how it all comes together though. The axle from our 750 fits but isn't long enough, maybe ya'll know which axle i should get would appreciate it
ADDED -
ISO Gribs
Heat Shields
Grill
Bobber Headlight
Mini Speedo
Solo Seat
VN 1500 Front End
Ear Shave
post #5 of 7 (permalink) Old 05-22-2012, 10:01 PM
Those look like 1500A forks,You should be able to put a 1500A reont wheek axle and spacers in there and the front brake as well the good thing is the A model front wheel matches the 750 rear wheel almost perfectly.
After going back for a second look you may be able to get by with a 1500 A model axle,wheel bearings and spacers.You may need to check to make sure your calipers are centered over the discs.are you sure it's not an 800 A front fork?
post #6 of 7 (permalink) Old 05-23-2012, 05:28 PM
Looks saaaweeeeet !...and BTW, a metric Harley front axle will work.
post #7 of 7 (permalink) Old 05-23-2012, 07:12 PM Thread Starter
kctrigger's Avatar
they are suppose to be 1500 forks come off a 96 model, and i'll try a local harley dealer to see if they got one i can get off of em
ADDED -
ISO Gribs
Heat Shields
Grill
Bobber Headlight
Mini Speedo
Solo Seat
VN 1500 Front End
Ear Shave
