in need of new brake fluid! how to? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 05-11-2012, 11:45 AM Thread Starter
Headbanger/Popes of Hell
ruger's Avatar
ok, it's time to replace the old brake fluid and put in some new fluid. what is the best way of doing this?
thanks guys.
ruger is offline
post #2 of 4 (permalink) Old 05-11-2012, 12:47 PM
gun slinger
centurynick's Avatar
pump brake handle hold the handle open bleeder screw repeat till there is clean fluid squirting out ( i usually rototate on each caliper ) also make sure the master doesnt go empty
2010' voyager
2005 1600 nomad sold
1987 kawasaki vulcan 750 SOLD
1985 kawasaki vulcan 700 parts bike maybe
lots of hand guns
3 cagers doors kicked in
centurynick is offline
post #3 of 4 (permalink) Old 05-11-2012, 12:54 PM
Do you really need to pump the lever? I would think simply opening the bleed screw a bit if would drain the master cylnder. Just make the MC level and add fluid as it drains. Do one caliper at a time.
Cover your bike with plastic anywhere you might spill fluid btw.....
post #4 of 4 (permalink) Old 05-11-2012, 01:51 PM
I take my caliper off and open the bleed value a bit, attach a clear hose to it, then compress the piston. All the old stuff gets pushed out, then fill from the MC, slowly pumping the lever, with new fluid and the piston still compressed. Once I get nice clean fluid and making sure there are no air bubbles, I close the valve, remount the caliper and then do the other side. Once it's done, I make sure the brakes are nice and firm, top off the MC if needed, and take off on a long test ride. Many ways to do it and this is just the way I do.
MCCT Mod
Pickup Mod
12 Volt Receptacle Mod
Memphis Shades Santa Cruz
Homemade Luggage Rack
NGK Iridium IX Spark Plugs
Harley Sportster Exhausts
Rotating/Flashing Tail Lights
170/80 Michelin Commander II
Saddlemen Highwayman Slant Jumbo Saddlebags
Bought 09/10 12.2k miles - 04/12 33.4k miles
CW-4 is offline
