Front Breaks making strange sound - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 04-11-2012, 04:28 PM Thread Starter
The front brakes make a "Air Pressure Release" sound when I use them. Does this happen to anyone? Any ideas what it might be?
Four wheels move the body. Two wheels move the soul.
kmswedberg is offline
post #2 of 7 (permalink) Old 04-11-2012, 04:52 PM
Where does the sound come from, master cylinder or the caliper??
Swagman is offline
post #3 of 7 (permalink) Old 04-12-2012, 01:26 PM
Crap, I WAS in 5th gear.
I'll take a hot at this. There are two sounds that come from the brakes (from the stock pads, at least.) You do hear the pads rub, and then you may also notice a clicking noise from the drilled rotors. The rubbing kind of sounds the same as if you rubbed your hand across a cardboard box.
Kelly2001 is offline
post #4 of 7 (permalink) Old 04-12-2012, 05:11 PM
I think like Swag does, but leaning more towards the master Cylinder.
post #5 of 7 (permalink) Old 04-13-2012, 12:40 AM
almost sounds like air in the lines
post #6 of 7 (permalink) Old 04-13-2012, 04:00 AM
you won't hear air in the lines unless there is a hole some where.
post #7 of 7 (permalink) Old 04-14-2012, 12:02 AM
that is usually how air gets in there.my xs400 had a little dry rotin the front line before i replaced it.scarey
