2004 front fork seals - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 03-21-2012, 12:04 AM Thread Starter
i have to replace my seals on my 04 vn750 and never done this before but i have been seeing some videos so i think i can handle it.
If anyone can help me i need to know what weight and how much shock oil i need to put back in each shock and also any other helpful hints would be wonderful.. thanks in advance
cdlegate is offline
post #2 of 5 (permalink) Old 03-21-2012, 01:09 AM
phurp's Avatar
hey man, This is the guideline that I used not too long ago. replacing the seals is actually pretty easy.
https://www.vn750.com/forum/showthrea...ght=fork+seals
This list was made by THE vn750 GURU. Lance 328.
Followed these instructions and had no problems.
A member named Roach also posted a vid on the fork seal replacement.
I highly recomend breaking loose, not removing, the allen head bolts on the very bottom of the fork tubes before you do anything.
If you dont have the parts yet, this is what i ordered from cheapcycleparts.com
Fork seal, dust: 92093-1197 order 2
Fork seal, oil: 92049-1230 order 2
Ring, snap: 92033-1201 order 2
Hope this helps you get started and finished.
1990 vn-750
metzler 880's
r/r relocated
iridium plugs
ngk plug caps
mf agm battery
ballancer and stator replaced. (Lance328)
Pro Tac Backrest
progressive fork springs
fork seals replaced
2003 kdx 220
frp chain gude
frp skid plate
acerbix hand guards
uni filter
phurp is offline
post #3 of 5 (permalink) Old 03-22-2012, 12:30 PM Thread Starter
ive ordered both those parts just not the snap ring...hopping to be able to resuse them
cdlegate is offline
post #4 of 5 (permalink) Old 03-22-2012, 09:58 PM
phurp's Avatar
I suggest getting the snap rings. They are the only thing holding the springs and everything else inside the tube. Maybe you can get yours out without mangaling them, but I could not, they get bent real easy.......jmho.
1990 vn-750
metzler 880's
r/r relocated
iridium plugs
ngk plug caps
mf agm battery
Pro Tac Backrest
fork seals replaced
2003 kdx 220
frp chain gude
frp skid plate
acerbix hand guards
uni filter
phurp is offline
post #5 of 5 (permalink) Old 03-23-2012, 06:34 PM
I posted the hillbilly/redneck method here :
https://www.vn750.com/forum/showthread.php?t=19760
