Which direction for progressive springs? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 07-30-2006, 08:18 PM Thread Starter
Hi all. I'm putting in progressive-wound fork springs and I'm not finding any directions in the box. But I remember reading somewhere - either here or in the directions before I lost them - that the springs should be oriented with the tightly-wound or loosely-wound end at the top to minimize noise.
Does anyone know which way to install the springs?
Thanks! Mark
Mark is offline
post #2 of 4 (permalink) Old 07-30-2006, 09:53 PM
I believe the tight wound end goes down.
Might want to wait for someone else to post to be sure though.
EDIT: I also believe I seem to be wrong, as Bulldog's how-to page should be just what you need.
Although I don't think the direction has anything to do with noise, as much as in how they perform
post #3 of 4 (permalink) Old 07-30-2006, 09:58 PM
Growling at the World...
bulldog485's Avatar
Send a message via Yahoo to bulldog485
Thanks! Mark
See http://www.bulldogsbike.com/forkseals.htm
The tighter would side goes to the top of the forks.
Evan Breyn ~ The Bulldog
2006 Harley Davidson Ultra Classic FLHTCUI ~ The Big Black Bitch ~ 26,000 miles.
2002 Kawasaki Nomad 1500 ~ The Red Dog ~ Traded in at 22,000 miles of smiles (purchased new 10/05 / Traded in 6/12).
1990 Kawasaki Vulcan 750 ~ Black Betty ~ 34,999.7 miles
VROC ~v~ 485
McHenry County Road Pirates
Chicagoland, IL
bulldog485 is offline
post #4 of 4 (permalink) Old 07-31-2006, 09:59 AM Thread Starter
Thank you Bulldog! This mod is inexpensive and an easy DIY job.
I'm putting in 10W oil. I drained 350ml out of 1 fork leg which seemed to be too much, and about 330ml out of the other. The manual says use 310ml for an oil change. So I'm a little confused on how much oil I'm going to put back in. Perhaps I should measure the oil height instead of volume?
Mark is offline
