Spongy - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 23 (permalink) Old 02-15-2012, 04:46 PM Thread Starter
Talking Spongy
Hi guys being new to th VN world and never having ridden a cruiser before is the suspension on them soft and spongy, I took the bike out today to see how it ran after doing the carbs battery plugs airfilters oil change and stuff and it seemed very bouncy on the rear end, I got back and stripped the forks and replaced the seals that should help as one side was leaking, as I say it may be normal and just because I'm used to my Fazer, what are your thoughts.
Swagman is offline
post #2 of 23 (permalink) Old 02-15-2012, 04:59 PM
rev it up's Avatar
crappy stock shocks
These stock shocks are total shyte !. No adjustment or FA. Riding two up is a nightmare with them. I have just ordered a pair of new ones off ebay,i will let you know what they are like when i get them. They are MDI or something like that and are £55.95 plus p&p. ALL VN 750 STOCK SHOCKS ARE SHYTE.
AGEING IS INEVITABLE,,MATURING IS OPTIONAL
VN 750 A8 1992.
27000 miles.
Imported from California
to UK in 1996.
New for 2012.
new filters(foam type)
replacement shocks(MDI)
Iridium plugs.
AGM battery(platinum)
brake pads(Kyoto)
(All on and running)
rev it up is offline
post #3 of 23 (permalink) Old 02-15-2012, 05:05 PM Thread Starter
Hi Rev the shocks on mine have an air valve and 4 numbers for adjustment, yes let me know what those shocks are like I may have to invest
Swagman is offline
post #4 of 23 (permalink) Old 02-15-2012, 05:10 PM
rev it up's Avatar
yes,,4 setting and air valve !,,you got crappy stock shocks there !!...lol. will let you know what shocks are like when arrive,,hopefully tomorrow.
VN 750 A8 1992.
27000 miles.
to UK in 1996.
New for 2012.
Iridium plugs.
brake pads(Kyoto)
post #5 of 23 (permalink) Old 02-15-2012, 05:13 PM
How much you weigh?
Yes the stock shocks are crap, but given you have an 86, I'd say they sound wore out. Did you try adding any air to them? (don't use a high pressure air hose, use a hand pump)
Fill each side with about 10% of your weight....(if they still hold air)
post #6 of 23 (permalink) Old 02-15-2012, 05:17 PM Thread Starter
Hi Km about 190lbs will try adding a little air and see if that helps if not will find some better shocks from somewhere
Swagman is offline
post #7 of 23 (permalink) Old 02-15-2012, 05:40 PM
Progressive Suspension link:
http://www.progressivesuspension.com...41&modelID=452
Metric product line:
http://www.progressivesuspension.com...inemetric.html
The 412, 430 and 440 series fit the vn750 according to the chart.
post #8 of 23 (permalink) Old 02-15-2012, 08:30 PM
JM2001's Avatar
Can't complain at all about my stock shocks. I put 28 pounds of air in each shock, 3 setting for 2 up, 2 setting for solo. Rides very good. 14,000 miles on the bike 2001.
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #9 of 23 (permalink) Old 02-16-2012, 11:26 PM
Been reviewing the Progressive site tonight and now remember that the 412 series is the most economical at $299.95 for each shock, either standard or heavy duty.
Wow, $600 bucks for new shocks.
http://www.progressivesuspension.com...ies/index.html
CORRECTION POSTED FEB 18.
THE PRICE QUOTED IN THEIR CHECK OUT IS FOR A PAIR OF SHOCKS, NOT INDIVIDUAL PIECES!
SO THE SET OF SERIES 412 IS $299.95
post #10 of 23 (permalink) Old 02-17-2012, 01:48 AM
bamamike's Avatar
Keep a check on ebay, I put Harley shocks on mine, new take offs from a new bike, paid $70 I think. People allways changing Harley shocks, got 11.5 inch ones to lower the bike for the wife, no problems so far.
Bike 1: (Wifes Bike Now)
Ear Shave / Coastered (142/42)
Fire & Steel Saddle Bag Supports
Fire & Steel Signal Relocators
Fire & Steel Luggage Rack
Fire & Steel Engine Guard
V&H Pipes
AGM
RR Relocated
Sissy Bar Extender
170 Rear Tire
Bike 2:
2008 Harley Davidson FLHX Street Glide
1584cc (96 CID)
AM/FM/WX/CD/MP3
https://www.vn750.com/forum/signaturepics/sigpic10325_1.gif
www.escambiariders.com
bamamike is offline
