Crack in Tire - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 10-09-2011, 01:52 PM Thread Starter
kcdude's Avatar
Crack in Tire
Hey guys, did a pre-ride inspection and found a tire problem. My bike has about 6,700 miles on it right now and I'm running the stock Bridgestones. The tread is getting low, and I had every intention on getting new tires in the spring. It's getting late in the season and I don't have the expenses for new tires right now. Looking at the pic, do you think I should put the bike in winter storage and call it quits early, or do you think it would be fine for a month or two? Maybe it's repairable?
Name:	2011-10-09 13.27.39.jpg
kcdude is offline
post #2 of 11 (permalink) Old 10-09-2011, 01:59 PM
Drive less, ride more...
theauhawk's Avatar
You don't say whether or not that tire is losing air pressure--and if so, approx how fast.
Judging from the pic you've provided though, it doesn't appear that the split in the tread penetrates to the materials underneath.
I would keep careful tabs on the future "progess" of this split, and also--do an air pressure check on the tire b4 throwing a leg over (even for short rides).
Later, after you install new tires, be sure to add "Ride On" tire sealant to your bike's new "shoes".
Many threads exist here already on the merits of different makes/models of tires, so I won't go into details here.
Good luck!...
'05 VN750
theauhawk is offline
post #3 of 11 (permalink) Old 10-09-2011, 02:01 PM Thread Starter
kcdude's Avatar
Thanks for the suggestions. As of now the tire is not losing air.
kcdude is offline
post #4 of 11 (permalink) Old 10-09-2011, 04:26 PM
You might want to get a strong light and a screwdriver to make sure that there is not anything in the crack. It likely is not a crack per sae, but cut.
I had a piece of metal that did that to me once. I opened up the cut and pulled out a small chunk of steel. If clean, You can fill it with rubber cement , and I would not be too worried about riding on it as long as it is not deeper than the tread depth of the adjacent area.
post #5 of 11 (permalink) Old 10-10-2011, 02:26 PM
Undercover Sportbiker
AJCruzin's Avatar
Looks more like a cut. Chances are you'll be OK, except that the cut is in the absolute worst possible direction. Check the depth with something not sharp to see if it goes below hte level of where the tread meets the carcass of the tire. If it doesn't, you should be OK for a while. You'd be better if it was turned 90 degrees - the way it is now, acceleration and decelration forces can potentially cause the cut to widen. Potentially.
AJCruzin is offline
post #6 of 11 (permalink) Old 10-10-2011, 05:49 PM
My first thought was that you ran over something nasty. KM is right about checking for any remains in the tire, as that could cause a blowout. X2 about cleaning it and keeping watch for progress.
Keep the dirty side down,
Hippie
hot_rod_hippie is offline
post #7 of 11 (permalink) Old 10-10-2011, 11:47 PM Thread Starter
kcdude's Avatar
Alright guys, thanks for the concern. I haven't driven it since I found the cut, so I'll give it a thorough check in the morning and report back with my findings.
kcdude is offline
post #8 of 11 (permalink) Old 10-11-2011, 10:52 PM Thread Starter
kcdude's Avatar
Figured I'd let you know what I saw since some seemed interested. The cut is deep, but not dangerously so. There was nothing lodged in there. Wonder what I ran over? Anyway, I'll probably try some rubber cement like KM mentioned. Going to take it easy until the end of the season, then stick on some new tires in the spring. Based on other threads, I'm thinking the Metzler ME 880's. Again, thanks for all the responses!
kcdude is offline
post #9 of 11 (permalink) Old 10-12-2011, 02:06 PM
AJCruzin's Avatar
Good thinking there KC!
AJCruzin is offline
post #10 of 11 (permalink) Old 10-12-2011, 02:21 PM
theauhawk's Avatar
You can buy good tires for your bike that are not ME880s.
But the 880s have an enviable track record of reliability and longevity.
Note also that the ME880 is the tire of choice out the factory door for both the Yamaha Raider and the Triumph Thunderbird. Both of these are of course bigger, heavier, & more expensive bikes than our VN750.
Just some food for thought....
'05 VN750
