Adjusting rear shocks - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 10-07-2011, 10:14 PM Thread Starter
New to riding and my 1994 VN750 is my first bike.
Wondering how to adjust the rear shocks and what should they be set at?
Thank you
bearsfan is offline
post #2 of 11 (permalink) Old 10-07-2011, 11:49 PM
If only it had 6th gear..
DavesVulster's Avatar
Hi, welcome, and you twist the top of the shock as it's a dial. Personal preference on the setting. I believe higher number is stiffer ride.
Dave
Mods:
Jetted, shaved & coastered
LED tail/plate lights
Added stuff:
Chrome levers
Hellcat windscreen
LED running lights
Home made 'Vita-Volt' meter
Foot rests on engine guard
Tunes
DavesVulster is offline
post #3 of 11 (permalink) Old 10-08-2011, 05:46 AM
rev it up's Avatar
Shocks
Set them to whatever you like !. It won't make any difference because they are crappy stock shocks !. no oil,no air in mine,,it makes no difference.
AGEING IS INEVITABLE,,MATURING IS OPTIONAL
VN 750 A8 1992.
27000 miles.
Imported from California
to UK in 1996.
New for 2012.
new filters(foam type)
replacement shocks(MDI)
Iridium plugs.
AGM battery(platinum)
brake pads(Kyoto)
(All on and running)
rev it up is offline
post #4 of 11 (permalink) Old 10-08-2011, 07:50 AM
JM2001's Avatar
Thank you
My bike has the stock air shocks. I run 28 pounds of air in each shock and have the settings on 2 for solo riding and 3 for riding with a passenger.
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #5 of 11 (permalink) Old 10-08-2011, 10:08 AM
Thank you
How much do you weigh? What type of riding do you do? You carry a passenger? Got saddlebags loaded with stuff?
What are the roads like where you live?
Suspension is adjusted using all these factors... So there is no one answer.
post #6 of 11 (permalink) Old 10-08-2011, 10:12 AM
Thank you
Suspension is adjusted using all these factors... So there is no one answer. Although I agree with rev it up's post.... The shocks are crap. If yours still hold air .. Pump them up with a Hand Pump to a about 10% of your total load on the rear as a good starting point.
post #7 of 11 (permalink) Old 10-08-2011, 10:17 AM
lol, I forgot about the air pressure. Never touched mine. Only the dials. You'll probably have to take some time and find what's best for you by riding it (aww, what a shame ) until you find what you like.
Dave
Mods:
Added stuff:
Chrome levers
Hellcat windscreen
LED running lights
Tunes
post #8 of 11 (permalink) Old 10-08-2011, 12:00 PM
2000 VN 750 Senior Member
I have read on this forum that the place to start for air pressure in our rear shocks under normal riding conditions is to divide the total load weight (rider and any extra gear) by ten. Therefore a 185 pound rider with an additional 15 pounds of gear in the saddle bags should start out with 20 pounds (185 + 15 = 200/10 = 20) of air in each rear shock and adjust for your particular riding style. I also read that the maximum pressure is 45 pounds I believe but this would be for new shocks in good condition I believe. Try to keep the two shocks balanced as to the same air pressure. Some prefer to use a hand pump to avoid over inflation and to not loose air upon removal of the air chuck. Check your pressure after riding for a bit to see if they maintain a steady pressure before you get overly involved in trying to find the perfect ride setting. Twisting the top cup between 1 and 4 is also a matter of personal riding style and feel.
I hope this and the other information given by others helps and welcome to the wild world of Vulcans.
Tom
Vulcan 2000
Vulcan2000 is offline
post #9 of 11 (permalink) Old 10-08-2011, 02:07 PM
Good info to know, thanks.
Dave
Mods:
Added stuff:
Chrome levers
Hellcat windscreen
LED running lights
Tunes
post #10 of 11 (permalink) Old 10-08-2011, 05:22 PM Thread Starter
Thank you that was very helpful
bearsfan is offline
Tags
adjustment , shocks , suspension
