Pics - Upsize & Stock Tires (Side by Side) - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 3Likes
post #1 of 67 (permalink) Old 09-24-2011, 11:41 PM Thread Starter
Patriot Guard Rider
The DEUCE's Avatar
Well, I purchase the Metzler ME 880 Marathon tires and since I had both stock and the upsized tires available I snapped a few shots for comparison.
Front - Upsize 110/90 - 19 on the left; Stock 100/90 - 19 on the right
Rear - Upsize 170/80 - 15 on the left; Stock 150/90 - 15 on the right
VIVERE175 likes this.
VN750 #9300 & VROC #33453
The DEUCE is offline
post #2 of 67 (permalink) Old 09-25-2011, 12:11 AM
Both the front and rear oversize tires do look noticeably wider than the oem sizes.
The front oversize does also appear enough taller to account for the reported correction of the speedometer.
My calculations of the diameter and circumference of the OEM and oversize rear tires indicate they are almost identical.
These pictures also seem to verify those calculations.
Thanks for the pics Duece. Very informative.
post #3 of 67 (permalink) Old 09-25-2011, 12:56 AM
... worth viewing 4 sure..... very educational w/ our own eyeballs !
tyvn Duece
post #4 of 67 (permalink) Old 09-25-2011, 01:05 AM Thread Starter
Patriot Guard Rider
The DEUCE's Avatar
tyvn Duece
I've read up on them and seen them on other bikes but never saw a side by side comparison and thought it would be valuable to many who are thinking about upsizing. BTW, the tires make the bike feel more stable both riding straight and handling curves.
post #5 of 67 (permalink) Old 09-25-2011, 09:00 PM
Niiiice !!!!
I REALLY like the visual look from the side of that Metz ! Its just dang purdy !
post #6 of 67 (permalink) Old 11-08-2011, 12:24 PM
Gadget35's Avatar
Send a message via MSN to Gadget35
Thanks this info was valuable thanks so much.
Gadget35 is offline
post #7 of 67 (permalink) Old 11-08-2011, 01:19 PM
Byorec's Avatar
Thanks for the info and pics, really helped me decide on the larger Metzeler tires for my bike. Already did front tire, lots of life left in rear tire, may be a while before I get the larger Metzeler there.
Byorec
2000 VN750
Over 37,000 miles
Battery-Minder Plus
Maintenance Free Battery
Ride-On
Upsized Metzeler ME880 Tires
Ear Shave
V&H Cruzers Exhaust
Mutazu Saddle Bags
F&S Saddlebag bracket
F&S Luggage Rack
Byorec is offline
post #8 of 67 (permalink) Old 11-08-2011, 08:25 PM
Concert connoisseur
wib714's Avatar
in the last pic be sure to take that part off the rim with the 7 holes in it and lube it up with moly 60 as well as the drive splines before reinstalling! there is a snapring that holds it in!
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
post #9 of 67 (permalink) Old 11-08-2011, 10:57 PM Thread Starter
Patriot Guard Rider
The DEUCE's Avatar
Lube was completely done prior to installation of rear wheel.
post #10 of 67 (permalink) Old 11-08-2011, 11:11 PM
If only it had 6th gear..
DavesVulster's Avatar
You got your 150's in man? How's it run????
Dave
Mods:
Jetted, shaved & coastered
LED tail/plate lights
Added stuff:
Chrome levers
Hellcat windscreen
LED running lights
Home made 'Vita-Volt' meter
Foot rests on engine guard
Tunes
DavesVulster is offline
