I want a fatter front tire... - Page 2 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #11 of 19 (permalink) Old 09-24-2011, 02:26 PM
If only it had 6th gear..
DavesVulster's Avatar
Ya man, I do hate riding on crappy roads with this bike. So many to choose from in Taxachussetts and some o' dem pot holes hurt!
Dave
Mods:
Jetted, shaved & coastered
LED tail/plate lights
Added stuff:
Chrome levers
Hellcat windscreen
LED running lights
Home made 'Vita-Volt' meter
Foot rests on engine guard
Tunes
DavesVulster is offline
post #12 of 19 (permalink) Old 09-24-2011, 04:23 PM
I could swear someone put a front end off a larger bike on the 750 without changing the neck, but not 100% sure what front end they used.
Perhaps someone can jog my memory on this and help you out also?
JD might know....Try sending him a PM:
https://www.vn750.com/forum/member.php?u=257
Yep; a 1500A front end has been put on a 750, altho it ain't hit the street. The triple tree bearings and neck/steering head length are the same between the two. No advantage, tho, as far as larger tire size; the 750 and 1500A use the same size tire and wheel, front and rear.
(Got the message, Darien; had to split the reply into three sections.)
In my reply to Darien's PM, I said it'd make more sense to use the same front end, and hunt for a wider wheel that'd fit between the fork tubes. A wider wheel is prolly gonna be smaller diameter, tho; I haven't seen a stock 19" wheel that could carry a tire wider than a 110 safely. (Doesn't mean there ain't one out there; I just haven't seen one, and haven't researched it.) Problem might be brake disc and caliper diameter and spacing, and axle diameter. Axle diameter isn't that big a problem; differences can be made up with different bearings, matching bearing outer diameter to the hub, and inner diameter to the axle. Brakes might be a whole different story...
Jim
J.D.
Kerrville, TX
'95 Vulcan 750 "Therapy II",
aka "Raggedy Ann"
'95 VN750 project
'03 VN800B "The Little Black"
'04 VN800E Drifter project
'93 VN1500A custom project
VROC #16185
GCVROC #33
J.D. is offline
post #13 of 19 (permalink) Old 09-24-2011, 04:30 PM
BTW, I know a guy that put an 800 front end on a 1500A; again, no advantage to trying an 800 front end on a 750, as the tire size on a VN800A is 90/21, and is tube type. Same guy turbocharged an early 1500 Classic...
Jim
J.D.
Kerrville, TX
aka "Raggedy Ann"
'95 VN750 project
VROC #16185
GCVROC #33
J.D. is offline
post #14 of 19 (permalink) Old 09-24-2011, 04:59 PM
Ummmm
Not 100% sure on the triple tree size, but I know for awhile the Harley Sportsters and Superglides used the same forks as the Vulcan has (Showa), but I believe some Harley triple trees were wider. This way would almost be a bolt-on (prolly using harley brakes tho due to mounts), then just adding axle spacers (might need to have em custom machined), and also using a Harley compat rim (I like spokes, dangit)...If ya got lucky (not in my personal exp) but may just need to swap the triple tree and add spacers...THAT would be a dream ! I'd do it meself...
Just a thought, bring yer triple tree to a Harley shop, and ask em if there's a wider available...avoid tellin em what its for though, lol...say its off a Sportster...*wink*...
I had Japanese forks on my original '72 Super...a 53 front end fit (paid $100, and then changed seals)....I wonder if most necks are compatible....just a matter of replacement then. And think...one could even go to 1" bars !!!!
post #15 of 19 (permalink) Old 09-25-2011, 01:42 PM
Originally Posted by darienmd View Post
I'm guessing it's in the "DIY Manual" file?
I might have moved it.. I am looking for it right now... you its still labeled OCR Tube sizes, and OCR Stem Sizes... they are not in the DIY manual
post #16 of 19 (permalink) Old 09-25-2011, 05:22 PM
Also...
Some custom shops which own a FloJet machine, could make you a custom triple tree...would be big bucks though, and IMO not worth it...
post #17 of 19 (permalink) Old 09-28-2011, 11:28 AM Thread Starter
yeah, big bucks is not something i have haha. thanks, though!
darienmd is offline
post #18 of 19 (permalink) Old 09-29-2011, 04:15 PM
Found this old post here...
Found this old post about 1500 forks on a custom...mentions Harley front ends too...
https://www.vn750.com/forum/showthread.php?t=4765
post #19 of 19 (permalink) Old 09-29-2011, 11:33 PM
Found this OCR website slim:
http://www.ohiocaferacers.com/
Check Tech tips as I can`t link directly to it.
Coversion Charts for Fork Tube Sizes & Steering Stem Bearings
Standard Fork Tube Sizes
Stock Steering Stem Sizes
