Master cylinder change - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 08-05-2011, 01:54 AM Thread Starter
All i needed for this was a phillips head screw driver, a 10mm and 14mm open ended wrench, I think it was a 5mm allen wrench, 1/4" i.d. clear tubing and brake fluid.
The first picture is of the old master cylider. Now i realize how bad the paint job from the previous owner really was.
The second picture is the brake lever and mirror removed.
The third picture is of the banjo fitting where the master cylinder attached to the other two brake lines behind the kawasaki emblem on the front of the bike
The fourth is of the bolt out and the two fittings apart.
the fifth is of the the two wires for the brake light sensor, make sure to take these off carefully and reattach them after.
ID:	3954   Click image for larger version
ID:	3955   Click image for larger version
ID:	3956   Click image for larger version
ID:	3957   Click image for larger version
Mick51 is offline
post #2 of 4 (permalink) Old 08-05-2011, 02:02 AM Thread Starter
the first picture here shows the new master cylinder on. It attaches just as the old one does with two bolts.
The second is how the bolt and banjo fittings fit together before they go back in.
ID:	3959   Click image for larger version
Mick51 is offline
post #3 of 4 (permalink) Old 08-05-2011, 02:07 AM Thread Starter
From here there was a lot of air in the system that needed to be purged. I tried regular bleeding, gravity bleeding and nothing worked. What worked for me to get the air out was a vacuum type method. I opened the bleeder valve and created a suction. I then squeezed the brake lever with the master cylinder cover off. This cause the brake fluid to rush into the brake lines and fill them up. This all in all was not hard to do works great for me now.
Mick51 is offline
post #4 of 4 (permalink) Old 08-05-2011, 02:31 AM
lphernan's Avatar
Woo Hoo! Great job. Glad its behind you now and you can go enjoy riding your scoot.
Louie
1995 VN750 - Work in Progress
2001 BN125 - Learning Bike
2004 GL1800 - All Done
lphernan is offline
