fogged brake window : front master - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 07-25-2011, 03:21 PM Thread Starter
jetmax's Avatar
Front brake window is fogged up. What are my options?
Do newer ones use glass windows?
Should I just bolt on a vn500 or vn900?
Kawasaki 1999 VN750 Mods: Relocate R/R, ETX15L battery ($44.89 Advance Auto)
Owned:
Kawasaki 1980 kz650, 1981 440ltd, 1982 750csr, 1983 550ltd, 1990 600r ninja,
1998 zx600e ninja Green, 1998 zx600e Purple,
Suzuki 1997 650 Savaga, Suzuki 1998 600 Katana
Yamaha 1982 550 Vision, Yamaha 2002 TTR125
Ducati 2001 900SS
jetmax is offline
post #2 of 3 (permalink) Old 07-25-2011, 05:10 PM
Make sure the master cylinder is perfectly level, remove the top carefully, and fill the reservoir up if needed to about 1/8 inch from the top.
Make sure the top diaphragm is pushed back, and replace the cover.
Unless you are leaking brake fluid somehow , you should not need to check the level for quite some time.
I find the window useless because you can't really get the reservoir lev without loosening it up on the bars and turning the just-so.
So always check the level as I described above.
post #3 of 3 (permalink) Old 07-25-2011, 07:14 PM
Hoser
junkyardroad's Avatar
I bought a replacement glass widow on ebay. Its about the size of a quarter and just siliconed in. Kinda expensive for what it is, but none of the plastics I tried failed eventually.
1986 VN750A(2) 12224 miles.
junkyardroad is offline
