bleeding fron brakes
ok so i got my master cylinder apart and replaced the O rings and spring but now I cant seem to get the calipers to bleed out......does anyone have any ideas? thanks
Sponsored Links | |||
Are the bolts on the MC cap frozen? That's the usual source o' the problem. Try dousing the bolts in PB Blaster - best solvent around for long-term rust and stuff. Then address the bolts with an impact driver - you'll have to replace those bolts, but that's cheaper than replacing the MC itself. Usually once you get under the cover, the clean-up is just a matter of patience.
C
I got the cap off but cant get the " piston" out of the housing..i removed the lock and rubber boot but cant get the piston to pull out
Originally Posted by hoggs750
View Post
C
yea I finally got mine out but not in great condition..lol mine looks a bit different from the one in the picture..ill try to get a pic of mine on here..thank you
Sponsored Links | |
Bookmarks |
Previous Thread
Next Thread
Thread Tools | |
Display Modes | |
Posting Rules | |
