Brake cable length? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 06-14-2011, 12:26 PM Thread Starter
thebeginning's Avatar
Brake cable length?
Anyone know the length of the stock front brake cable on our bikes? I'm getting a new cable for 12" mini apes so I need something 4" longer, but I can't measure the line very easily while it's on the bike.
Also while you're here (hah) - should I also get a new clutch cable? I was told that could be rerouted but I'm not sure.
thebeginning is offline
post #2 of 7 (permalink) Old 06-14-2011, 01:44 PM
Stones750's Avatar
I want to say it was around 19" I know the 30" I got was more than enough for my 18" apes try looking up part number 03-5923 its a 23 inch hose from bikers choice I believe. I can try and double check my old brake hose when Im at home but I'm almost 100% sure. The clutch cable can be re- routed and for 12" apes it should work just fine.
86 Vn750
De-Goated
Ears shaved
"Custom Pipes"
"Custom Seat"
Apes
Stator Mod
Currently @ 23k and counting
Stones750 is offline
post #3 of 7 (permalink) Old 06-15-2011, 10:27 PM Thread Starter
Awesome. I'm assuming this will work fine then?
http://www.motorcycle-superstore.com...ake-Lines.aspx
And the throttle/electronics cables can be rerouted as well?
post #4 of 7 (permalink) Old 06-16-2011, 12:42 PM
Stones750's Avatar
Sorry I missed your reply, yes those look fine just keep in mind the 23" should be exactly what you need but the 25" is the best way to play it safe. Just make sure theres no leaks after you install it and bleed the brakes. Hope it all works out! Happy Riding.
86 Vn750
De-Goated
Ears shaved
"Custom Pipes"
"Custom Seat"
Apes
Stator Mod
post #5 of 7 (permalink) Old 06-16-2011, 07:49 PM
You can measure cables and hoses without removing them by running pinstripe tape down them. It will stick on and follow curves, start where you wish to measure, cut it where it stops then take it off lay it down flat and measure it.
And I won't say anything about calling brake lines "cables" because I'll just get dumped on for "correcting" someone....
post #6 of 7 (permalink) Old 06-16-2011, 08:04 PM
Stones750's Avatar
lol I figured I'd let it be to...and thats a good tip with the tape, I couldve saved a lot of time
86 Vn750
De-Goated
Ears shaved
"Custom Pipes"
"Custom Seat"
Apes
Stator Mod
post #7 of 7 (permalink) Old 06-16-2011, 09:00 PM Thread Starter
Haha feel free to correct...in fact I'd rather have people correct as much as possible. Trying to get out of the newb stage sooner rather than later
