crappy stock shocks - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 06-06-2011, 07:12 PM Thread Starter
rev it up's Avatar
crappy stock shocks
hi all. i feel like a Alien,being from the UK that is. lol. im wondering if anyone can tell me if its possible to bin my stock shocks because they have always been rubbish,,and replace them with shocks from a 1990 harley 1200cc sportster. i know where a set of these shocks are,,but do not know the eye to eye measurements of them etc. also would you suspect they may be a little worn because of their age ?. many thanks.
rev it up is offline
post #2 of 10 (permalink) Old 06-06-2011, 10:30 PM
https://www.vn750.com/forum/showthread.php?t=18527
Note KM`s post #2 for info on Sportster shocks.
ie. any Sportster shock 11 1/2" - 12 1/2" long "eye to eye" should work.
post #3 of 10 (permalink) Old 06-07-2011, 07:33 PM
baldy's Avatar
The only problem is.....Harleys ride worse then our 750s.
Are the shocks leaking fluid or have you checked the air pressure in the shocks. I run around 20psi or lower at the #2 setting and it rides fine on these pot hole laden roads here in Maine. I up the pressure if i have a passenger and set on #3 or #4.
01' VN750
Jardine cross over exaust
Kyriakin grips and foot pegs
Modified seat and backrest
Luggage rack
Spline lube
93' VN750 getting TLC
Decals and mirrors
ACCTs to MCCTs
Degoated with Harley mufflers
Pick-up coils at .020
Spline lube
baldy is offline
post #4 of 10 (permalink) Old 06-08-2011, 01:29 PM Thread Starter
rev it up's Avatar
Thanks. i put air in them,around 35psi,and i've tried lower. they must have an air leak because when i re-check them a day or two later they are back to zero. i have them set on 4,,and with a passenger on they ground out on any form of pot hole. im just looking for a cheaper option then buying new.
post #5 of 10 (permalink) Old 06-08-2011, 10:37 PM
Big Dumb Viking
asbrand's Avatar
Send a message via AIM to asbrand Send a message via MSN to asbrand Send a message via Yahoo to asbrand
Stupid question here... How do you put air in the shocks? And where do you check the pressure?
Never even thought about having to do that...
-Az
http://www.asbrand.com
1989 Kawasaki Vulcan 750
Upgrades so Far:
Analog Voltmeter
PFIII Windshield
RAM GPS Mount w/Garmin GPS
Cigarette Lighter Power Adapter
Saddlemen's Classic Explorer Seat
Pro-Tac Driver's Backrest
LED Tail Light
LED Rear Turn Signals
Luggage Rack
Storage Trunk
Engine Guard w/Highway Pegs
Radiator Grill Cover
Turn Signal Relocation Bracket
Saddlebags
Floorboards
asbrand is offline
post #6 of 10 (permalink) Old 06-08-2011, 11:05 PM
There is an air valve on the top of the shock, just above the damper adjustment collar, that looks just like the valve on the tire.
The black plastic cap is just a little bigger than on the tire, and sticks out horizontally from the mount by the eye.
A fork shock pump with a zero loss gauge is the best way to inflate and check pressure. 0-43 psi working range.
A bicycle hand pump can be substituted.
DO NOT USE A GARAGE AIR COMPRESSOR HOSE. Too much volume will wreck the shock.
post #7 of 10 (permalink) Old 06-09-2011, 04:38 PM Thread Starter
rev it up's Avatar
ahh,,just found out from the owner of the harley shocks,that off his 1200 sportster they are 13 and a half inches eye to eye. so no good for my vn. damn,they were cheap price too.
post #8 of 10 (permalink) Old 06-10-2011, 07:52 AM
Big Dumb Viking
asbrand's Avatar
Thanks! I had no idea...
As you can tell...I am *not* a mechanic of any sort.
-Az
Upgrades so Far:
Analog Voltmeter
PFIII Windshield
LED Tail Light
Luggage Rack
Storage Trunk
Saddlebags
Floorboards
asbrand is offline
post #9 of 10 (permalink) Old 06-10-2011, 09:06 AM
They would still work. If you set the preload for a sag of a whole inch, you'd be at 12-1/2....which is stock.
post #10 of 10 (permalink) Old 06-10-2011, 12:28 PM Thread Starter
rev it up's Avatar
oh,ok. so would they still be safe when im 2 up with luggage ?. it was the thought of them being 1" over that concerned me. as i would (i think) need them set fairly high for 2 people plus camping gear. you got me thinking about them again now.lol. thanks.
