Need help with Front Brake - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 06-06-2011, 09:55 AM Thread Starter
JM2001's Avatar
I accidently got air into the brake line coming out of the reservoir. I used a One Man bleeder and a quart of brake fluid trying to get pressure to the brake lever. No luck. Fluid comes out with no air bubbles. I tried bleeding the brakes the old fashion way. No luck. I have been bleeding the system for 6 hours and cannot get pressure to the brake lever. Any suggestions will be appreciated. The brake was very good until I tried to rotate the reservoir.
Jim
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #2 of 9 (permalink) Old 06-06-2011, 10:25 AM
I use a short piece of hose and a big syringe to push the fluid back up through the bleeder screw to the master cylinder,be sure to not get any fluid on the paint .It is some of the best paint stripper known to man.
I think you will have to use regular bleeders for this ,since I believe the speed bleeders have a one way check valve in it.The fluid will push any air back up into the reservoir and you need to keep an eye on it and pull some out as it fills up.When you no longer see bubbles your brakes should work normally.
post #3 of 9 (permalink) Old 06-06-2011, 10:33 AM Thread Starter
JM2001's Avatar
Thanks Denny, I'm open to any suggestions. I'm now on my second quart of brake fluid. I've got the cleanest brake lines in the history of the Vulcan.
JM2001
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
degoated
All LED lighting
JM2001 is offline
post #4 of 9 (permalink) Old 06-06-2011, 06:49 PM
rev it up's Avatar
This may sound crazy !!,,but it works most of the time. check you have no leaks(obviously),,,then leave the reservoir top off,then tie the brake lever to the throttle grip with reasonable pressure,,leave for a few hours (over night is better). this will allow the air bubbles to escape. undo the tie and the brakes should be working fine all being well. its never failed to work for me yet. good luck.
rev it up is offline
post #5 of 9 (permalink) Old 06-06-2011, 07:46 PM Thread Starter
JM2001's Avatar
Thanks Rev, I've heard about that before. I might as well give it a try. I"ll leave it overnight.
JM2001
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
degoated
All LED lighting
JM2001 is offline
post #6 of 9 (permalink) Old 06-06-2011, 08:13 PM
I believe I would try Rev's suggestion first,if you have the time.He's right about it working most of the time,The method I suggested works well if you need to get back on the road quickly,but his is easier for sure.
post #7 of 9 (permalink) Old 06-07-2011, 01:13 PM Thread Starter
JM2001's Avatar
Thanks to Rev and Denny for your advice. Leaving the bike overnight with the brake lever in DIDN"T work, sorry to say. It was worth a try. I'll have to try Denny's first suggestion. If that doesn't work I'll be off to the dealership.
JM2001
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
degoated
All LED lighting
JM2001 is offline
post #8 of 9 (permalink) Old 06-07-2011, 02:00 PM
clock152's Avatar
if you have speed bleaders try opening them both up at the same time.. this seemed to work for me.
clock152 is offline
post #9 of 9 (permalink) Old 06-08-2011, 11:26 AM
Having the same issue, Im gonna try the shooting fluid up through the bleeder today
1992 vn750, 16000 miles
seat shaved , lowered 2 inches in rear, ears shaved, degoated, cpanel is gone just a drag specialties 2.5" speedo
awaiting some pipes
Toddmurdoch is offline
