What makes my brakes tick? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 16 (permalink) Old 06-05-2011, 05:12 PM Thread Starter
'03 VN750 "Rosie"
bstew7890's Avatar
I hear a fast ticking noise whenever I apply the front brakes at high speed. It sounds like when you spin the rear wheel of a 10-speed bicycle. The brakes seem to slow me down just fine but I would like to know what's making that sound?
'03 VN750 "Rosie"
Purchased in June 15, 2010
Lubed Splines
Lubed and Adjusted Clutch Cable, Throttle Cables.
Relocated Voltage Regulator
Brakes Bled
Luggage Rack
Lazy Rider Bag
Leather Saddle Bags
Legitimate Title!! (finally!) Aug 30, 2010
New AGM Interstate Battery Sept 15, 2012
2008 Hyosung GV250 (sold!)
bstew7890 is offline
post #2 of 16 (permalink) Old 06-05-2011, 07:48 PM
Your rotor or pads gave crap on them?
Prop up the front end and spin the wheel to see where the sound is coming from. Might be a worn pad....or something stuck on the rotor.
post #3 of 16 (permalink) Old 06-05-2011, 09:13 PM
1985 VN-700
L2fish's Avatar
I bet your pads are worn. I noticed today what look like little metal clips that contact the rotor when the pads get to replaceable range.
L2fish is offline
post #4 of 16 (permalink) Old 06-06-2011, 12:37 AM
dfam4's Avatar
I have that same ticking noise when applying the brakes. Nice to know I'm not alone. I'll check out my pad/roters next weekend. If you check out before I do, let all of us know.
tim - Seattle Area
dfam4 is offline
post #5 of 16 (permalink) Old 06-06-2011, 09:20 AM
cglennon's Avatar
My '06 does the same thing, but I only notice it at low speeds. It is more of a fast, faint ticking on my bike. It's been there since I got the bike with 3K miles on it, with no problems braking since or now at 12K miles. I have been considering it normal. I will stay again that mine is not very loud or noticable. If yours is very loud, then maybe it is worth looking into (i.e., excessive wear).
Chris Glennon - Portland, OR
cglennon is offline
post #6 of 16 (permalink) Old 09-17-2011, 11:50 PM
If only it had 6th gear..
DavesVulster's Avatar
Mine has done that since I've owned it. I watched a video of someone here riding and heard it on the video when they braked, so I thought its just the way the discs are and I haven't worroed abount it since.
Dave
Mods:
Jetted, shaved & coastered
LED tail/plate lights
Added stuff:
Chrome levers
Hellcat windscreen
LED running lights
Home made 'Vita-Volt' meter
Foot rests on engine guard
Tunes
DavesVulster is offline
post #7 of 16 (permalink) Old 09-18-2011, 01:51 AM
HAWK
Ccspinner's Avatar
I believe it is due to the drilled rotors, the pas hits the holes and makes noise. Mide did that and I know had good brakes.
just a thought.
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Ccspinner is offline
post #8 of 16 (permalink) Old 09-18-2011, 12:46 PM
I hear it on mine too mainly at lower speeds and I have new pads on mine as they were getting worn down and due for replacement. I have only had my bilke since spring but noticed it before and after replacing the pads. I had already guessed that it was due to the drilled rotors used on our bikes. I would not describe it exactly as a ticking noise but I guess that is probably the easiest way to desacribe it.
rockinray is offline
post #9 of 16 (permalink) Old 09-25-2011, 08:07 PM
Couldnt resist, but...(jk)
Sorry, couldnt resist...
Could be the Azherbakistani terrorist trigger for the bomb planted in your gas tank....*wink*...
...sorry....I HAD to....the title was just BEGGING for it....*innocent grin*
post #10 of 16 (permalink) Old 09-25-2011, 09:01 PM
just a thought.
There you have it. Good enough explanation to me.
Dave
Mods:
Added stuff:
Chrome levers
Hellcat windscreen
LED running lights
Tunes
