1992 front brake drag - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 05-23-2011, 06:35 PM Thread Starter
Hey guys, a minor issue with my new (old) 750, im having issues with the front brake dragging.
Yesterday i was going about 40 and all of a sudden there was a massive drag, then by the time i came to a complete stop the brake lever was bound up (i couldnt pull it toward me it was that tight andthe front tire was locked up tight
once I let the pressure off by releasing the bleeder valve i was able to get her home by using the rear only. SO i put new fluid and bled it off, but something is amiss cause once i use the front brake there is drag until i bleed it off again.
Thanks for any help
TOdd
1992 vn750, 16000 miles
seat shaved , lowered 2 inches in rear, ears shaved, degoated, cpanel is gone just a drag specialties 2.5" speedo
awaiting some pipes
Toddmurdoch is offline
post #2 of 4 (permalink) Old 05-23-2011, 07:51 PM
I had a similar issue w/ my 750, but I observed only on a very hot day. I solved the problem (with brake cylinder cover removed) by cracking the bleeder valves for a 8-10 hours, allowing an occasional drip, allowing any _stubborn_ air bubble to vacate. I believe the hot weather w/road heat expanded any air bubble within the line, thus applying my brakes. Topped off fluid level and reassembled. I have not experienced this problem since.
Good Luck
post #3 of 4 (permalink) Old 05-23-2011, 09:52 PM Thread Starter
Thanks WT, will give it a shot, I think ill pull it of and clean and lube everything up this week too.
awaiting some pipes
post #4 of 4 (permalink) Old 05-24-2011, 12:01 AM
The OEM hydraulic brake lines are recommended to be changed every 4 years.
I wonder if they could be deteriorating on the inside.
These SS lines will last the life of your bike, and may cure your problem.
I know at least two members here have installed them and like them.
http://cgi.ebay.com/ebaymotors/ws/eB...m=370502455061
EQPlayers install:
https://www.vn750.com/forum/showthrea...Bsteel%2Bbrake
