rear tire, uneven wear? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 05-09-2011, 10:04 PM Thread Starter
Concert connoisseur
wib714's Avatar
looking at my back tire today I noticed straight down the center over half of it is bald but a little of it still has tread. I've been noticing a little wobble in the front but believe the rear tire may be causing it. has anyone else had uneven wear like this, will try to post a pic tomorrow!
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
post #2 of 10 (permalink) Old 05-09-2011, 10:20 PM
Do you downshift and "chirp" (skid) the rear tire when slowing down?
post #3 of 10 (permalink) Old 05-09-2011, 10:52 PM
sounds like you have worn that one out regardless.After you get past the normal tire life(past the wear bars in the tread pattern)normal wear patterns go out the window.
it is just time for a new tire,did you like the way that one handled or did it not get as long of a life as you expected?think about these factors and decice if you want another one or something different.
post #4 of 10 (permalink) Old 05-10-2011, 05:21 AM Thread Starter
Concert connoisseur
wib714's Avatar
I have to put a rear on almost every summer (dunlop 404) think I'll be trying a diff brand this year as I only get 8 - 10000 miles on these. I've only skid it a few times (close call with deers) but wouldnt think enough to cause bald spots!
42,000 miles
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
wib714 is offline
post #5 of 10 (permalink) Old 05-10-2011, 08:54 AM
That's about the best you'll do with a 404,the Metzeler is a little more expensive,but after going thru several 404's on the rear I put a Metz on the back of mineand put about 5000 on it before selling it and it was wearing very well ,plus the handling was great wet and dry.
post #6 of 10 (permalink) Old 05-10-2011, 10:53 AM
flitecontrol's Avatar
Got 15,000 from Pirelli MT66 on rear. Front still looks good.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #7 of 10 (permalink) Old 05-19-2011, 04:32 PM
Undercover Sportbiker
AJCruzin's Avatar
Once your tread is worn down that far, you can easily be sliding the rear wheel slightly while braking and not know it. When the rear on my Ninja 650 went, I knew it was time becuase at speed with a crosswind, the rear was sliding around.
AJCruzin is offline
post #8 of 10 (permalink) Old 05-19-2011, 05:54 PM
Thanks for this insight AJ. It makes perfect sense, but having such limited riding time, I have never experienced wearing out a set of tires yet. It will be something to watch for when my tires get down to the wear bars.
I have read that most rapid tire failure occurs in the last 10% of a tire`s tread life.
That is a good enough reason for me not to try to squeeze the last few hundred miles out of worn out "rags".
post #9 of 10 (permalink) Old 05-19-2011, 08:50 PM
baldy's Avatar
Sounds like what the others have said. Time to get a new tire.
In reading your 1st post......is the wear a bit to the left of the center of the tire. If that is what you consider uneven wear that is normal. The crown of the road makes the tire wear a bit off center. I'm still running my CT and loving it. Granted I've only got around 3000 on it so far but I'm expecting at LEAST 40,000 miles on it.
01' VN750
Jardine cross over exaust
Kyriakin grips and foot pegs
Modified seat and backrest
Luggage rack
Spline lube
93' VN750 getting TLC
Decals and mirrors
ACCTs to MCCTs
Degoated with Harley mufflers
Pick-up coils at .020
Spline lube
baldy is offline
post #10 of 10 (permalink) Old 05-19-2011, 09:26 PM Thread Starter
Concert connoisseur
wib714's Avatar
it is wore a little more on that side but straight down the center there is tread in a spot (very little) but slick on the rest. And yes, I know its time for a tire. LOL
42,000 miles
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
wib714 is offline
