Cutting springs for lowering - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 14 (permalink) Old 05-05-2011, 10:46 PM Thread Starter
bigbluezuk's Avatar
Has anybody done this?
1995 VN750 - 10K
bigbluezuk is offline
post #2 of 14 (permalink) Old 05-06-2011, 12:10 AM
Into the Darkness
NetMatrix's Avatar
Not recommended the springs ont he shocks are cut to the size they need to be for the opening. I had a friend do that on his bike which was a Honda, and after he cut the springs to lower it a little so his girlfriend could ride the bike the shocks actually went out. They make different size shocks you can buy to put ont he bike.
English Version
ACCT to MCCT conversion video
https://www.vn750.com/forum/showthread.php?t=18235
ACCT to MCCT Conversion Thread created by wib714
https://www.vn750.com/forum/showthread.php?t=17917
Proximity Construction
NetMatrix is offline
post #3 of 14 (permalink) Old 05-06-2011, 01:53 AM
HAWK
Ccspinner's Avatar
In the front there are spacers that can be cut down and not cut the springs.
The rear just get shorter shocks, much safer.
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Ccspinner is offline
post #4 of 14 (permalink) Old 05-06-2011, 07:17 AM
Your still doing the same thing, and both are real bad ideas. Cut the spacer, or even the spring, you lessen your forks amount of travel. Given it only has about 3 1/2 inches to start with, any reduction over an inch would likely be very dangerous.
The best way to lower the front is to first increase the pre-load by installing a longer spacer...then raising the fork tube up in the upper clamps. Would not go much more than an inch.
This way you retain your fork travel, and the added preload helps avoid insuuficant trail issues over bumpy roads.
Ideally the best route to lower the rear is with a set of lowering blocks , but given that the stock shocks blow... I'd go with a shorter aftermarket set instead.
The only reason I can see for lowering the bike is because you are "height challanged" ... And it's alot easier to just lower the seat.....
post #5 of 14 (permalink) Old 05-06-2011, 01:00 PM
Progressive sells a kit to lower the forks. You have to pull the forks off to do it, but it's easy...... With the over sized tires and Saddlemen seat, I was on my tip-toes, now I'm both feet flat on the ground
oh, and if you are getting shorter rear shocks, you might want to consider the HD ones.... I bought the 10.5" standard shocks and have to turn the preload all the way up to keep from bottoming with the old lady on the back..
dariv is offline
post #6 of 14 (permalink) Old 05-31-2011, 01:58 PM
Some people like the looks of a lowered bike and are too old to be doing 120 mph through the twisties.LOL
post #7 of 14 (permalink) Old 05-31-2011, 02:01 PM
I have installed a set of shocks from a Suzuki Savage on mine and raised the forks in the clamps about an inch.
post #8 of 14 (permalink) Old 05-31-2011, 03:54 PM
Papa Smurf's Avatar
While not height challenged- I am not tall and have debated lowering the bike an inch or two. Looks like replacing the rear shocks may be the way to go but I don't have the $ for those good ol' 11 inch progressives. How tall are the Savage's shocks? Did you have to modify them any way to get them on?
Papa Smurf is offline
post #9 of 14 (permalink) Old 04-10-2014, 05:29 PM
Hi my friend... install these HD rear shocks and do that you said ..... approximately how many inches I'm getting lower???
biker123 is offline
post #10 of 14 (permalink) Old 04-10-2014, 05:33 PM
How many inches....
biker123 is offline
