Final Drive & Speedometer lube? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 05-04-2011, 09:28 PM Thread Starter
VulcanCruizer's Avatar
I got my new Shinko 230 Tour Master Tires today. Before I put everything back together tomorrow I'm greasing the spline's. My question is can I use the moly 60 to grease the final drive and speedometer as well?
1989 VN750
Purchased 4/26/2008 @ 27,320 Mi
Upgrades:
Travelcade Mustang Seat
SpitFire Tinted Quick Release Windshield
Degoat, Drilled & Jetted
Leather Saddle Bags
Johar Signature Grips
Deka ETX15L Powersports AGM Battery
NGK DPR7EIX-9
Upcoming:
1991 VN750 Project Bike
Purchased 4/30/2011 @ 31,970 Mi
VulcanCruizer is offline
post #2 of 4 (permalink) Old 05-04-2011, 10:41 PM
'03 VN750 "Rosie"
bstew7890's Avatar
The final drive is actually included in Fergy's directions. I think a cable lube would be better for the speedometer. I need to do it this summer, after converting to MCCTs...
'03 VN750 "Rosie"
Purchased in June 15, 2010
Lubed Splines
Lubed and Adjusted Clutch Cable, Throttle Cables.
Relocated Voltage Regulator
Brakes Bled
Luggage Rack
Lazy Rider Bag
Leather Saddle Bags
Legitimate Title!! (finally!) Aug 30, 2010
New AGM Interstate Battery Sept 15, 2012
2008 Hyosung GV250 (sold!)
bstew7890 is offline
post #3 of 4 (permalink) Old 05-04-2011, 11:13 PM
No. You are not supposed to use cable lube on the speedometer. It turns.... You need to use grease. Moly seems a bit expensive , but would work fine.
Only cables that slide on a non constant bassis should use regular cable lube... which is usually just light oil.
post #4 of 4 (permalink) Old 06-11-2011, 02:11 AM
'03 VN750 "Rosie"
bstew7890's Avatar
Thanks! glad I spoke up in order to get corrected.
'03 VN750 "Rosie"
Lubed Splines
Brakes Bled
Luggage Rack
Lazy Rider Bag
Leather Saddle Bags
