Removing both wheels - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 04-30-2011, 07:53 AM Thread Starter
Getting new tires, is there a way to remove both tires at the same time so I only have to make one trip to get them mounted?
Thanks
Macman is offline
post #2 of 5 (permalink) Old 04-30-2011, 08:09 AM
johnm's Avatar
I'm wanting to do the same thing and will be picking up this lift from Harbor Freight this weekend.
http://www.harborfreight.com/automot...lift-2792.html
John
1989 VN750
VROC#31798
I'm bad with names. May I just call you dumb?
johnm is offline
post #3 of 5 (permalink) Old 04-30-2011, 08:25 AM
That, or put the bike on center stand and remove the rear wheel the usual way. Then put a jack under the engine and lift up the front end and remove the front wheel.
pappa is offline
post #4 of 5 (permalink) Old 04-30-2011, 11:27 AM
Or a concrete brick with a towel over it...anything to get the front wheed up a few inches.
Be care full you do not have any large cats or kids that may try sitting on the bike after the wheels are off...they can upset the balance and make it fall backward.
post #5 of 5 (permalink) Old 04-30-2011, 12:16 PM
Should use a strap around center stand while it's up, as in fergy's spline lube:
https://www.vn750.com/forum/showthread.php?t=17274
and a couple of plastic milk cases underneath for jack stands(I know, ghetto, but it works).
TuxedoSeven is offline
