optimum tire pressure - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 06-22-2006, 08:48 PM Thread Starter
VN750 MOM recommends that air pressure be kept at 28psi in the front tire and 28-32 (depending on load) in the rear tire. Everyone I know keeps the pressure much higher than this. I know that the ideal pressure is different for different tires but isn't MOM's recommendation too low for *any* tire?
How much pressure do you maintain in your tires? What tires do you have?
Gargoyle is offline
post #2 of 11 (permalink) Old 06-23-2006, 12:09 AM
I second the question. The sidewall pressure on my tires is 40 PSI. Thats a huge difference than the manual pressure. Should I go closer to 40?
InsuredDisaster is offline
post #3 of 11 (permalink) Old 06-23-2006, 02:02 AM
Once Banned
cegodsey's Avatar
I always run mine around 32. Why? Who knows... I always ran my Maybach around that psi until I bought some low profile tires/wheels. Now I run 35+
2000 A16
Drilled baffles
$65 leather saddle bags
Kuryaken grips
relocated R/R
de-badged
25,000+ original owner miles
cegodsey is offline
post #4 of 11 (permalink) Old 06-23-2006, 08:20 AM
"ya can't live forever"
artman's Avatar
Dunlop 404 s here, 37 front and 41 rear.
artman is offline
post #5 of 11 (permalink) Old 06-23-2006, 09:45 AM
Hey Artman, I'm thinking about going with the 404's pretty quick here. You have any complaints about them, or think they shine in any area? You get your's online or local?
post #6 of 11 (permalink) Old 06-23-2006, 10:24 AM
The pressure printed on the sidewall is the maximum pressure for the tire - not necessarily the "best" pressure. You'll get better traction if you run less pressure. But if you run your pressure too low, you risk having the tire break loose from the wheel. Because of this, when you carry more weight (like a passenger) you should run the pressure near or at maximum. But when you ride solo, you can bring that pressure down some and have better handling.
Mark is offline
post #7 of 11 (permalink) Old 06-23-2006, 10:52 AM
artman's Avatar
No sir no complaints. Good straight line running and great traction in wet conditions. You can get them pretty cheap online but I do like to support the local guys. I believe the total cost front and rear installed and splines greased was near $ 250.00
artman is offline
post #8 of 11 (permalink) Old 06-23-2006, 06:44 PM
Ditto on the 404's they are a good tire for the money. Got mine at Ron Ayers and had the dealership put them on. They wanted 30.00 more per tire then RA
Woody is offline
post #9 of 11 (permalink) Old 06-27-2006, 12:38 PM
Gnarly Jokester
norsseman's Avatar
Location: Southwest of Ruby Ridge, Geiger Heights, Washington, USA.
Artman... That was quite a good deal, my dealership here in Spokane, WA
would have charged at least 450.00
norsseman is offline
post #10 of 11 (permalink) Old 06-27-2006, 02:28 PM
artman's Avatar
Yeah I thought so also. It's a small shop and local and now he has all my business. My buddies also now go there, so it works well for everyone.
artman is offline
