Front axle - cotter pin or deathtrap? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 03-25-2011, 01:13 AM Thread Starter
bigbluezuk's Avatar
I noticed the other day on my motorbike that the front axle on the right side (while sitting) has a hole in the end. Is there suppose to be a cotter pin or something there? It looks like it could just fly out while turning or something?
Paranoid much or did my previous owner have a death wish?
Snapshot is attached. The location I am talking about is the hole towards the right end of 41068.
Thanks!
bigbluezuk is offline
post #2 of 8 (permalink) Old 03-25-2011, 01:29 AM
Don't know for sure why the hole is there, but mine's the same way. I'm thinking that you might be able to stick something in the hole to hold the axle when you are tightening or loosening the nut on the other side so that it doesn't just spin. I'm sure someone else will chime in on this.
post #3 of 8 (permalink) Old 03-25-2011, 02:28 AM
HAWK
Ccspinner's Avatar
There is not a cotter pin for that, don't worry.
That hole is for removing the axel, when you remove the not and loosen the bolts on the bottom you can put a screwdriver in the hole and twist and pull.
The Axel has a sholder so it cant go in and can only be pulled out from that side.
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Ccspinner is offline
post #4 of 8 (permalink) Old 03-25-2011, 02:48 AM
KIMMERLING's Avatar
I thought the same until people on the forum set me straight. I had a large cotter pin in there for a week or two....doh!
Ventura guards
MadStadt mount
Givi windshield/Heated grips
Backoff
Riderbeads
Givi 52 topcase
OEM centerstand
Headlight modulator
Battery tender
KIMMERLING is offline
post #5 of 8 (permalink) Old 03-25-2011, 09:12 AM Thread Starter
bigbluezuk's Avatar
Thanks a lot!
post #6 of 8 (permalink) Old 03-25-2011, 02:05 PM
The Reanimater
jthill524's Avatar
Location: A Little Town Along I-5 in Northern California
Or use a tool like this.............
JaY
"Veronica"
2002 VN750 Vulcan
Rebuilt Engine
ACCTs lubed w/TOC Springs
Pick-up Coils Gapped at .018"
Splines Lubed
Deka MF AGM EXT15L Battery
NGK Iridium IX Spark Plugs
R/R Relocation Fix
New Rear Rack
Stock Seat Repadded
Ext-BackRest
jthill524 is offline
post #7 of 8 (permalink) Old 06-19-2011, 07:41 PM
Mattman's Avatar
What a relief! I just noticed this yesterday on my new (to me) '94 VN750. I was 50 miles from home and was enjoying a Coke while admiring my bike and when I saw this I freaked! Now all I have to do is still get around to working on the ACCT and I will be able to rest easy for a while
Matt
Matt
Passaic County, NJ
1994 VN 750
April 2011- 30K miles
TOC MCCT 4/2012
New-to-me extended backrest 5/2012
Tourmaster bags 5/2012
Replaced driveshaft coupler and final drive-- ignored the spline lube recommendation too long and got burned 8/2012
Back on the Road 9/2012
De-POOGSed 6/2013
NGK Iridium Plugs 7/2013
New AGM battery 4/2014
Mattman is offline
post #8 of 8 (permalink) Old 06-19-2011, 09:40 PM
Since this thread got reserected...
For what? looks like an adjustable spanner, not an axle wrench. Good for shocks and your steering head, not sure why you'd need one to pull a front axle.''
