Lowering my 750 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 01-09-2011, 09:19 PM Thread Starter
14sec vulcan
Talking Lowering my 750
Hey everyone im wanting to lower the back of my vulcan but im broke, I was thinking about goin old school and making the rear a hardtail, does anybody have pics of solid pieces that replace the rear shocks and if so how long did u make them. Thanks
14 sec 750 is offline
post #2 of 9 (permalink) Old 01-10-2011, 11:05 AM
baldy's Avatar
There are many materials you could use to do this. Go to a steel distributor and look around at the different materials. Use your imagination and picture it on the bike. When lowering it most go no more then 3" so not to have to replace the front fork springs. One thing that is possible to lower the front without putting shorter fork springs is to loosen the fork bolts and bring the fork tubes up, but I wouldn't suggest more then an 1" unless you use lowering springs. With shorter fork springs you can go as low as you want.
01' VN750
Jardine cross over exaust
Kyriakin grips and foot pegs
Modified seat and backrest
Luggage rack
Spline lube
93' VN750 getting TLC
Decals and mirrors
ACCTs to MCCTs
Degoated with Harley mufflers
Pick-up coils at .020
Spline lube
baldy is offline
post #3 of 9 (permalink) Old 01-10-2011, 08:08 PM Thread Starter
14sec vulcan
I have already lowered the front just like u described ,and I took your advice and went and picked up some 1 inch square bar thanks for everything.
post #4 of 9 (permalink) Old 01-11-2011, 01:25 AM
If you lower the rear with struts and make a hardtail out of it, you will run into a couple of problems. One is obviously a very rough ride. The mushy rear suspension and super comfortable seat are two things I like about the Vulcan. Another issue is going to be lack of ground clearance. I regularly drag the pegs on mine with the stock ride height. The last problem will be stress on the frame, shock mounts, and swing arm. These parts were designed to be used with shocks, and if you make it solid, with no shocks to absorb impacts from bumps, potholes, etc, it will drastically increase the stress placed on these parts, possibly to the point of bending or breaking them. Real hardtail frames have a very strong triangulated structure designed to handle these forces, the Vulcan doesn't.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
post #5 of 9 (permalink) Old 01-11-2011, 06:13 PM
Jerry you have outlined the concerns I have whenever I have read about someone "hardtailing" a vn750. I didn`t have all the technical knowledge to identify details you have, but you have pointed out some items that anyone considering this mod needs to seriously study IMHO.
post #6 of 9 (permalink) Old 01-11-2011, 07:28 PM Thread Starter
14sec vulcan
Thanks alot I really didnt put too much thought into what could go wrong with doing this mod I think I might look for shorter shocks. I would like to know if someone has done this and if so did they have any trouble.
post #7 of 9 (permalink) Old 01-11-2011, 07:53 PM
I think OEM shocks are 12.5". IIRC someone said a week or so ago that they had gone down to 11" shocks. No personal knowledge of this mod to pass on.
post #8 of 9 (permalink) Old 01-14-2011, 12:46 PM
10.5" shocks, will work with the stock rear tire... or for an even cheaper option you can make some lowering plates the move the lower shock mount back and up, to achieve up to three inches of drop.
post #9 of 9 (permalink) Old 05-19-2011, 03:32 PM
I have shocks from a suzuki savage on mine
