A goofy question about front fork springs. - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 12-26-2010, 04:53 AM Thread Starter
Heading to the DARKSIDE!
BRET H's Avatar
When I rebuild my forks..I will be changing over to progressive springs(OEM size) NOT the lowering ones. With the added strength and control of these springs....do I need to put air pressure back in the fork tubes? Can I just leave the springs only and still get a good ...controlled ride. My seals now are leaking....but not badly. I don't even know if there is any air left in the forks. I have the progressive 412? series 2" lowering springs on the back now and I really like them. What do you all think?
BRET H is offline
post #2 of 3 (permalink) Old 12-26-2010, 01:27 PM
Only the earliest 2-4 model years (not sure exactly when they stopped) had air adjustable fork tubes anyway. I may be wrong, but I would say to go ahead and try the new progressive springs out without any added air pressure if you want to. It is just a matter of screwing the caps off and pumping them up a bit if you feel the need.
post #3 of 3 (permalink) Old 01-11-2011, 10:45 PM
Intelligent Redneck
kennyw's Avatar
I put the progressive springs in my Honda V45 when doing a fork rebuild. The instructions actually said to not put air back in.
kennyw is offline
