New rider. - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 13 (permalink) Old 11-16-2010, 11:25 PM Thread Starter
New rider.
Brand new rider, first bike.. 94 vn750.
needs new tires.
my question is should i get the standard size or go for the over sized ones? from what i gather the wider the tire the better the traction?
Thanks!
JZyne is offline
post #2 of 13 (permalink) Old 11-17-2010, 12:15 AM
phurp's Avatar
Welcome to the forum. The Bigger tires are the way most here on the forum seem to go. I like the feel of the bike with bigger tires. Lots of good info on this site to help you have a good experience with your bike. Check out the "verses" section if you have not allready.
1990 vn-750
metzler 880's
r/r relocated
iridium plugs
ngk plug caps
mf agm battery
ballancer and stator replaced. (Lance328)
Pro Tac Backrest
progressive fork springs
fork seals replaced
2003 kdx 220
frp chain gude
frp skid plate
acerbix hand guards
uni filter
phurp is offline
post #3 of 13 (permalink) Old 11-17-2010, 01:02 AM
Ceal's Avatar
Welcome. Definitely check out the Vulcan Verses, in there you will find recommendations about which tire sizes are the best fit for our bikes. If you go too big they might rub against something.
Ceal is offline
post #4 of 13 (permalink) Old 11-17-2010, 01:26 AM
I put the oversized on my 94 and really like them. Went with the Metzler 880's.
post #5 of 13 (permalink) Old 11-17-2010, 09:47 AM
baldy's Avatar
Welcome to the forum. Check the versus and if you don't see what you are looking for just ask. Someone can direct you or many will answer the question. That is the great thing about this site. Many many knowledgeable people here to help with problems and questions.
As for tires....you can go up to a 170/80/15 in most brands for the rear and the Metzler 880 offers a 180/80/15 that will fit. The biggest you can get on the front is a 110/90/19 unless you do some mods to the front forks and fender. I have gone to the darkside with a car tire on the rear and love it so far, but for someone new to riding I suggest sticking with MT while you are learning and building confidence.
Hope this helps.
01' VN750
Jardine cross over exaust
Kyriakin grips and foot pegs
Modified seat and backrest
Luggage rack
Spline lube
93' VN750 getting TLC
Decals and mirrors
ACCTs to MCCTs
Degoated with Harley mufflers
Pick-up coils at .020
Spline lube
baldy is offline
post #6 of 13 (permalink) Old 11-17-2010, 10:05 AM
Drive less, ride more...
theauhawk's Avatar
For what it's worth: I have over 20,000 miles riding time on the VN750, both with the factory installed tire sizes and the oversized tires.
I can definitely recommend the oversized tires--especially for a new(er) rider.
The over-sized tires will give your bike a more stable feel. They also actually improve the looks of the bike, too.
I went with the 170/80/15 on the rear, and the 110/90/19 on the front--and currently I use the Metzeler brand "ME880" tires. These sizes still fit the bike just fine.
These tires have almost 10,000 miles on them, and look good for about another 10,000. The factory installed tires were completely worn out at 11,000 miles....
If whoever installs your rear tire has a bit of trouble getting the larger size tire past the bike's swingarm, just let some air out of the tire, until it clears.
After you put a few hundred miles on the new tires, install "Ride On" tire sealant in them. This is a great hedge against a flat tire.
Check out some of the other threads here (by using the "search" function above) to learn more about this sealant.
'05 VN750
theauhawk is offline
post #7 of 13 (permalink) Old 11-17-2010, 03:28 PM
Welcome to the Vulcan madness.
I don`t have enough experience riding to offer any personal advice on the tires, but the majority of riders here who have changed over seem to like the oversize tires both front and rear. I have a few thousand more miles of wear in my tires before they need replacing, and will probably go with the 110/90-19 on the front and darkside the rear with a Vredestien or Kumho 165/80-15 car tire (CT). I haven`t decided on a brand yet for the front. Some here have installed the less expensive Kenda Kruz tires with complete satisfaction too. If you ride on a lot of wet roads you may find the Metzlers better.
I will be installing *Ride-On* tire sealant/balancer in the front MT, and would do the rear too, if I were putting a MT on there.
Here`s Daniel Meyer`s review of using the Ride-On on his Valkyrie:
http://lifeisaroad.com/forum/index.p...sg2738#msg2738
Ride-On website. Note this is the specific formulation for motorcycle tires:
http://www.ride-on.com/prod_mot.asp
Check Ebay, better deals are sometimes found there.
After getting some riding experience and wearing out a set of MT on your bike, you may be interested in trying a CT. Here is Daniel Meyer`s reason for going to the darkside:
http://lifeisaroad.com/stories/2004/...eDarkSide.html
post #8 of 13 (permalink) Old 11-20-2010, 01:29 AM Thread Starter
Put my order in this morning. This is what I ended up with...
110/90-19 (62H) Pirelli MT66-Route Front Motorcycle Tire
1197940006
$68.99
170/80-15 (77H) Pirelli MT66-Route Rear Motorcycle Tire
1200720003
$96.99
Got them from jakewilson.com I got free shipping but couldn't find any current discounts other than $10 dollars off my next purchase which im sure i'll end up using so it all works out.
Thanks everyone for the feedback!
JZyne is offline
post #9 of 13 (permalink) Old 11-20-2010, 02:07 AM
1197940006
$68.99
1200720003
$96.99
seems to be a feir price on what has been reported to be a good tire,WVShaneb is running the pirelli and you can check with him for a first hand report.
post #10 of 13 (permalink) Old 11-20-2010, 08:08 AM
flitecontrol's Avatar
I have over 12,000 on mine and will get several thousand more barring road hazards.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
