Front tire change question - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 11-01-2010, 12:58 PM Thread Starter
Papa Smurf's Avatar
About to change my front tire this afternoon and I had a question about the forks. May be dumb, but what stops them from extending fully and messing up me trying to get the new tire back on? I read the verses on the front tire change and it doesn't seem to mention anything about adjusting the psi in the forks when changing the tire. The service manual recommends reading up on it in the forks section however.
I don't have any fancy stand or anything. Just a jack and the center stand.
Papa Smurf is offline
post #2 of 4 (permalink) Old 11-01-2010, 02:13 PM
flitecontrol's Avatar
Been a while since I did mine, but IIRC, put a 2X6 (or two) under the center stand to elevate the rear end. Then tied a 50 lb. sack of dog food to the luggage rack, which raised the front enough to remove the tire. The forks only go down so far, and you shouldn't have a problem getting the tire off and on..
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #3 of 4 (permalink) Old 11-14-2010, 08:41 PM
gun slinger
centurynick's Avatar
Na u won't need anything under the center stand I used a jack under the front of the frame too hold the bike from doing a noise dive. I torqued everything went for a short ride re torqued then rolled out
centurynick is offline
post #4 of 4 (permalink) Old 11-14-2010, 09:39 PM
One good tip is to tie the center stand forwards to keep it from folding up on you.
Tags
front tire
