Fork Seals - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 10-19-2010, 12:53 PM Thread Starter
Fork Seals
Ok I need to replace the fork seals on my 02 750 and was wondering if anyone had used the leak proof seals that are listed on cheapcycleparts.com. the link is http://www.cheapcycleparts.com/produ...oof-fork-seals
I would prefer to use these since they are not made out of rubber and would last longer but I want to make sure that they will work before I order them. I am also wondering if they include all four seals or if I will need to get another set.
Loganwolf05 is offline
post #2 of 8 (permalink) Old 10-19-2010, 01:13 PM
93VN750's Avatar
Cant' see why they wouldn't work, the idea behind them makes sense. Make sure that you fork tubes are smooth as burrs and nicks will ruin any seal.
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #3 of 8 (permalink) Old 10-19-2010, 03:39 PM
baldy's Avatar
The leak proof ones suck! I had some put on by a bike shop and they lasted only 100 miles before BOTH were leaking. Go with a factory or a better brand. The money you spend isn't that much more and you won't have to replace them again soon. The bike shop went good on mine and I told them I would pay the extra if needed for the better brand seals. I have 8000 miles on since and no problems.
01' VN750
Jardine cross over exaust
Kyriakin grips and foot pegs
Modified seat and backrest
Luggage rack
Spline lube
93' VN750 getting TLC
Decals and mirrors
ACCTs to MCCTs
Degoated with Harley mufflers
Pick-up coils at .020
Spline lube
baldy is offline
post #4 of 8 (permalink) Old 10-19-2010, 05:40 PM
Yes they suck..^
Stick with Kaw part ones if you can.
post #5 of 8 (permalink) Old 10-21-2010, 05:08 PM Thread Starter
ok thanks guys I have one front fork leaking a little and it is causing my front tire to wear out uneven. I will go back with the kawi parts.
post #6 of 8 (permalink) Old 10-21-2010, 08:08 PM
I bought this set of oil and dust seals from Pyramid about a year ago.
How do these rate compared to Ma Kawi`s fork seals?
Should I put them on, or get new ones from the stealer?
http://cgi.ebay.com/ebaymotors/Kawas...Q5fAccessories
post #7 of 8 (permalink) Old 10-21-2010, 08:39 PM
baldy's Avatar
I wouldn't blame a leaking seal for tire wear. The tires wear more on the left of center due to the crown of the road. If it is cupping it could be a balance issue. However you should still replace the fork seals.
01' VN750
Luggage rack
Spline lube
Decals and mirrors
ACCTs to MCCTs
Spline lube
baldy is offline
post #8 of 8 (permalink) Old 10-21-2010, 11:54 PM
MANIC MECHANIC
vulcanjoe's Avatar
those are the ones I put on they are the same manufacturer as the factory seals just in different packaging
34k so far
VN750.com member #613
Keep the shiny side up
coastered
de-goat and baffles removed
jetted 42-150 2 shims
Earshaved with unifilters
inside of tank coated
spline lube
Shindengen FH012AA r/r
TPE stator
Saddlemen saddlebags
2001 HD fatboy solo seat
Fergy's coil relay mod
vulcanjoe is offline
