Front Wheel Bearings - Clymer manual error - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 2Likes
post #1 of 13 (permalink) Old 05-12-2006, 11:06 PM Thread Starter
Exclamation Front Wheel Bearings - Clymer manual error
I pulled my wheels the other day to replace the tires and noted that one bearing on the front had a definite "click" when manually rotated. There's a great bearing supply place near me so I ran down at lunch and picked up a pair of double sealed units for < $15.
Digging into Clymer's for replacement instructions takes you to pg 360 (for me). The relevant, erroneous, instructions read:
"8. To remove the right- and left-hand bearings and distance collar, insert a soft aluminum or brass drift into one side of the hub.
9. Push the distance collar over to one side and place the drift on the inner race of the lower bearing.
10. Tap the bearing out of the hub...."
Of significant note is Figure 21. From the description and figure it would seem that the distance collar could be moved aside from either end and either bearing driven out. This, however is NOT the case.
The inaccuracy with manual stems from the construction of the wheel itself. The distance collar has a shouldered section inside the hub into which it, presumably, rests to affect the pinching of the bearing but also as a means to locate it coaxially with the bearings themselves.
In my situation I had a fair amount of rust around the outer race of the bearings where they contacted the hub. Having never before made this repair I was unfamiliar with how far the distance collar would dislocate to pound out the opposite bearing. For a fair period of time I thought I had moved it as far as possible and was currently pounding on the inner race of the bearing when in actuality I was pounding the shoulder for the collar; the wheel itself!
The correct repair would involve working with the wheel flat on its side, rotational direction going clockwise, on a padded surface. More explicitly, speedometer mount down. In this configuration the distance collar was easily displaced, the bearing removed (follwed by the collar), then plenty of operating room was available to avoid the internal shoulder and drive out the remaining bearing.
Fortunately I did not damage the internals of the hub, but who knows what a solid hit on the inner shoulder could have done to my wheel. Having a 50% chance of guessing right based on the manual's inaccuracy was frustrating which is why I hope anyone in a similar situation finds this first.
*In case it is pertinent, my 750 is a '95. I suppose it is possible the wheel construction changed somewhere in the product's development.
Barbwired likes this.
RepairmanSki is offline
post #2 of 13 (permalink) Old 02-20-2014, 05:31 PM
Alpha Geek
Hexadecimus's Avatar
I'm getting ready to do this while I'm putting tires on, but are you sure you remove the left bearing first from the right side? With "rotational direction going clockwise" and "speedometer mount down", you're working the opposite from what my manual says.
I'm not sure what the Clymer manual is. I only have the PDF of the factory manual. Seems to me that it has you take things out through the right side, tapping from the left side (bolding is mine):
Insert a metal rod into the hub from the left side, and remove the right side bearing by tapping evenly around the bearing inner race.
Remove the remaining bearing by tapping evenly around the bearing inner race. The distance collar comes out with the bearing.
[clean pack etc.]
Insert either bearing so the seal is outward
Press the wheel bearing (right side) into the hub until it stops at the bottom of the hole.
Hexadecimus is offline
post #3 of 13 (permalink) Old 02-20-2014, 08:41 PM
...wow...a 2006 bump....gotta be a record....
post #4 of 13 (permalink) Old 02-21-2014, 05:14 AM
Big Nick's Avatar
front bearing 1986.
I bashed away at mine for a good while, becoming quite frustrated and increasing hammer size as I went. I do recall having the speedo drive out and that's about it. But it was a trouble, glad I didn't get too carried away with the force part of it.I got new wheel bearings in and happy with it.
Who walks into the Lions Den, and comes out alive?
The Lion!
12 inch apes
1986 A3 series 750
Slash cut stainless mufflers
170 rear tyre
Custom cyane blue paint, wheels included
Relocated regulator rectifier
Solo mod
Stainless washable oil filter
Six pack rack
LED indicators and flasher unit.
Replaced CDI
Coasters
Penrite 10/50
Oil pressure hot at 1000 rpm 20 psi, 4000 rpm 60 psi
Shows 67000 kms
Jets 38 idle Mains 120 changed to 40 idle 135 main.
Big Nick is offline
post #5 of 13 (permalink) Old 02-21-2014, 08:23 AM
Pics?
post #6 of 13 (permalink) Old 02-21-2014, 09:31 AM
I rented a blind hole puller from auto zone & it worked great.
Link
post #7 of 13 (permalink) Old 02-21-2014, 05:27 PM
...see ?....Kanuck's "in the groove"....
post #8 of 13 (permalink) Old 02-23-2014, 11:09 PM
Alpha Geek
Anyone know for sure which side they come out of? I'll assume the factory manual is right..?
Yeah, well.. resurrect old threads or end up with 10 new ones every year on the same topics. I asked before and didn't get a definite answer for thsi forum's preference. But I've seen that make a mess out of a really good forum and my view is to keep it together.
Thorn likes this.
post #9 of 13 (permalink) Old 02-24-2014, 09:19 PM
I never saw it....sorry....
And this forum will get messed up over my dead fookin body....
post #10 of 13 (permalink) Old 03-05-2020, 09:58 AM
MSattler's Avatar
I plan on installing the new progressive springs, brakes, and tires this weekend. I am glad I found this post. My question is do you need a bearing puller from harbor freight or rented from a loan a tool, or do you just tap it out like this post suggests?
'08 Road King Classic
'86 VN750:
Ear Shave, K&N Filters, Mean Streak Seat, AGM battery, Blue Wire Mod, Pick-up Coil Mod, Timing Advance Mod, NGK Iridium Plugs and Wire, LEDs, Bed Liner Paint Job, Over-sized Tires, New Brakes, New Fork Seals, Progressive Springs, Kick Stand Mod, Highway Pegs, 40/140 No Shims, Vance & Hines Exhaust, New Grips, Extra Wide Emgo Handle Bars
John 8:44, REV 2:9, REV 3:9 - If you were kicked out of 109 bars, would you think the problem was you, or the 109 bars?
MSattler is online now
