Front brake locking up - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 09-14-2010, 02:04 PM Thread Starter
Finally riding again!
Norm's Avatar
I have a major issue...My front brakes wont disengage sometimes...generally when it is hot. It will lock up so bad that I cant even get the bike to move in 1st gear. If I let it sit a while it will be fine. I recently filled up the resvoir and everything looked clean. HELP..I dont want to get stranded or mess up something.
Norm
'93 750
Left to me by a great friend who just passed away.
Norm is offline
post #2 of 6 (permalink) Old 09-14-2010, 02:25 PM
I had that problem before. I removed and cleaned the calipers. That fixed it for me.
post #3 of 6 (permalink) Old 09-14-2010, 03:38 PM
X2 to niterider`s suggestion. That was my first thought too, before I saw his post.
Check the pads too. Make sure one of them is not binding up somehow.
post #4 of 6 (permalink) Old 09-14-2010, 04:52 PM
dirtrack650's Avatar
Mine were sticking and grabbing. Changed the brown crap known as brake fluid and all is better now. Air will build up, add a little crap to the mix because it's old fluid and your brakes will bind up.
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Black 750 Spectre handlebars
SunPro Volt Meter (Amazon)
Maier bug shield (JCW)
Bar Ends anti-vibe (JCW)
Emgo air filters
Tank bag-Eclipse
Tail bag-FroZone Cooler
Back Rest-Igloo 6 pak cooler
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Sporster XL Mufflers
LED's-stop,tail,turn,marker
Pickup coil mod to .45mm
Silverstar headlight
Rotella T6
dirtrack650 is offline
post #5 of 6 (permalink) Old 09-14-2010, 05:12 PM
DT
Just checked the service/maintenance schedule, and the brake fluid should be drained and changed every 15k miles or every 24 months. Good catch dt, I never thought about the brake fluid.
post #6 of 6 (permalink) Old 09-16-2010, 07:24 PM
Clean fluid works wonders. I swapped the Dr. Pepper in my system to some good, fresh, DOT4 and the brakes are 100% better. But do take the calipers off, clean and lube those puppies up too.
CW-4 is offline
