suspention settings for the robust rider - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 07-29-2010, 10:17 PM Thread Starter
miked's Avatar
Being a big 6 ft.,300 lbs, I would like to see how other big guys set their suspension up for comfort/safety?
miked is offline
post #2 of 4 (permalink) Old 07-29-2010, 10:38 PM
MANIC MECHANIC
vulcanjoe's Avatar
I am 6ft 330 I use 30 lbs air dampers set on 2
34k so far
VN750.com member #613
Keep the shiny side up
coastered
de-goat and baffles removed
jetted 42-150 2 shims
Earshaved with unifilters
inside of tank coated
spline lube
Shindengen FH012AA r/r
TPE stator
Saddlemen saddlebags
2001 HD fatboy solo seat
Fergy's coil relay mod
vulcanjoe is offline
post #3 of 4 (permalink) Old 07-29-2010, 10:59 PM
You are almost identical in size to me.
My understanding is the factory preload is #2, and pump rear shocks pressure to 10% of weight to be carried, ie #30 psi for a #300 rider.
This is a preliminary setting, adjust to your comfort.
Clymer manual says a #150 rider should have the preload at factory setting of #2 and atmospheric pressure in the shocks.
Maximum weight to be carried on the 750 is ~ #400, so if you are fully loaded set the preload to 3 or 4 (?) and pump it up to max of 43 psi cold.
Others may have more fine tuned directions.
post #4 of 4 (permalink) Old 07-30-2010, 07:24 AM Thread Starter
miked's Avatar
Thanks for the input --Am going to set this weekend and ride!
miked is offline
