Front wheel wobbles on axle (!!) - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 22 (permalink) Old 07-28-2010, 04:34 PM Thread Starter
brilder's Avatar
Bought this bike about a month ago and noticed a little low-speed shudder in the front wheel. At first, I thought the rotors were a little warped, then I realized it was happening regardless of whether the brakes were being applied.
After a brief examination, it turns out I can tilt the front wheel on it's axle! I can wiggle it about 2 degrees side-to-side. WTF! Dangerous
I'm thinking either new bearings or new wheel. Neither seems like a huge hit to the wallet. Going to try taking off the wheel tonight for a closer look.
'02 Kawie VN750
'06 Suzie SV650S
Passenger backrest & bar hacked off with a coping saw
Seat crudely mounted to rear with door hardware
Kury Grip on throttle, shredded rubber on left grip
Fish-tank beads in reed valve hoses
One rear view mirror
Riding checklist:
-Duct tape
-Leatherman
-Texas Pete
ALL SET!
brilder is offline
post #2 of 22 (permalink) Old 07-28-2010, 04:43 PM
MANIC MECHANIC
vulcanjoe's Avatar
When mine did that it was the bearings here is the part number 601B6302U $12.54 each from ronayers.com you might be cheaper to go through a bearing supplier.
34k so far
VN750.com member #613
Keep the shiny side up
coastered
de-goat and baffles removed
jetted 42-150 2 shims
Earshaved with unifilters
inside of tank coated
spline lube
Shindengen FH012AA r/r
TPE stator
Saddlemen saddlebags
2001 HD fatboy solo seat
Fergy's coil relay mod
vulcanjoe is offline
post #3 of 22 (permalink) Old 07-28-2010, 04:45 PM
MANIC MECHANIC
vulcanjoe's Avatar
On mama Kaw's bearings the first numbers are the parts fiche location the numbers after the letter are the "industry number" U denotes it is a sealed bearing. Here is the link to the page at www.bearingsdirect.com you will need the 2 sides rubber sealed
34k so far
coastered
spline lube
TPE stator
post #4 of 22 (permalink) Old 07-30-2010, 02:15 PM Thread Starter
brilder's Avatar
Finally took off the wheel to investigate the wobble. It is not good.
Where there's supposed to be a self-contained axle bearing and globs of grease, there's this:
Rusty metal shavings and loose ball bearings At least now I know what the problem was. New bearings are cheap, thank goodness.
'02 Kawie VN750
'06 Suzie SV650S
Riding checklist:
-Duct tape
-Leatherman
-Texas Pete
ALL SET!
brilder is offline
post #5 of 22 (permalink) Old 07-30-2010, 02:30 PM
clock152's Avatar
nothing that some Seafoam, JB weld and red RTV can fix!...lol
clock152 is offline
post #6 of 22 (permalink) Old 07-31-2010, 07:08 AM
that happened to me, go buy a bearing puller from harbor freight for about 20 dollars (the one that when you screw it in it spreads) and pull it out. I will post a pick of my puller tonight. So, don't worry it is not the end of the world.
Harley sportster fenders
custom raked front end
custom exhaust
vn800 tank and guages
modified seat and recovered
rear frame chopped
custom wiring harness
airbox removed
hzhardy is offline
post #7 of 22 (permalink) Old 07-31-2010, 07:10 PM
Concert connoisseur
wib714's Avatar
I'd say thats pretty well shot, going out to try to wiggle my wheel now!
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
post #8 of 22 (permalink) Old 07-31-2010, 07:38 PM
Concert connoisseur
wib714's Avatar
mine is good, whewwwww
42,000 miles
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
wib714 is offline
post #9 of 22 (permalink) Old 08-01-2010, 02:48 AM
KIMMERLING's Avatar
Im gonna wiggle mine!
Ventura guards
MadStadt mount
Givi windshield/Heated grips
Backoff
Riderbeads
Givi 52 topcase
OEM centerstand
Headlight modulator
Battery tender
KIMMERLING is offline
post #10 of 22 (permalink) Old 08-01-2010, 02:59 AM
Cheman's Avatar
After seeing your bearing, and my water pump bearing, I'm gonna wiggle it too.
Cheman
1986
Purchased 7/03 w/13000 mi
Sold10/10 27,000miles
Ear shave
V&H Cruisers
Tim Parrott stator
Iridium Plugs
AGM Battery
Splines lubed
Clear Alternative LED brake light
TOC mcct
Mutazu LN Hard saddlebags
Chad's floorboards
Current ride-2009 Honda VTX1300
Cheman is offline
