Trouble installing new front brake pads.. - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 07-17-2010, 09:29 PM Thread Starter
artemis_f0wl's Avatar
Send a message via AIM to artemis_f0wl Send a message via Yahoo to artemis_f0wl Send a message via Skype™ to artemis_f0wl
well, I did the rear brakes and spline lube with no problems, but these front brakes are killing me!
I got the new pads on and trying to install the caliper back on to the rotor, but it seems as if there isn't enough room for the rotor to slip between the new brake pads. I've been futzing with it for about an hour now and I am at the end of my rope with it! Can anyone help me understand the secret to getting this done right?
NIL ILLEGITIMUS CARBORUNDUM
Phil aka Art
"Vanessa"
1995 VN 750 (bought as 2nd owner 11/2008)
26,440 miles
Stator replaced (55 Days!)
V&H Cruisers
Relocate rear turn signals
Highwayman Saddlemen bags
Wingerline Highway bars
Ear Shave
Rejet carbs
R/R relocate
Kuryakin ISO Duallys all around
HD Heritage seat
12" ape hangers
To Do:
Some sort of new grips
Mirrors
Paint Job- should I do it myself?
artemis_f0wl is offline
post #2 of 11 (permalink) Old 07-17-2010, 09:44 PM
Did you push the piston all the way back into the caliper?
post #3 of 11 (permalink) Old 07-17-2010, 09:50 PM Thread Starter
Well, I pushed with all I could, but it doesn't appear to be moving so I presume that to mean the piston is depressed fully into the caliper.
Phil aka Art
"Vanessa"
26,440 miles
V&H Cruisers
Ear Shave
Rejet carbs
R/R relocate
HD Heritage seat
12" ape hangers
To Do:
Mirrors
post #4 of 11 (permalink) Old 07-17-2010, 09:56 PM
ohio_redneck75's Avatar
it will be level with the calipar if its all the way in. you may have to crack the line to get it all the way in.
2002 vn750,7800 mile,homemade drag pipes,harley heratige seat,honda sissybar,led rear turn signals,
iridium plugs,marbled,110/90/19 kenda kruz front,
170/80/15 kenda kruz rear,saddlebags.
whats to come****handlebars,highway pegs
ohio_redneck75 is offline
post #5 of 11 (permalink) Old 07-17-2010, 10:06 PM Thread Starter
Well it's not flush at all..
I cracked the brake line and removed the pads, hoping to push the piston into the caliper further. Here are some pix of what I'm dealing with.
ID:	2979   Click image for larger version
ID:	2980   Click image for larger version
Phil aka Art
"Vanessa"
26,440 miles
V&H Cruisers
Ear Shave
Rejet carbs
R/R relocate
HD Heritage seat
12" ape hangers
To Do:
Mirrors
post #6 of 11 (permalink) Old 07-17-2010, 10:35 PM
Bronson's Avatar
When you pushed did you use a clamp? On car calipers I usually use an 8 inch C clamp or a special caliper tool set that I have; (glorified C clamp). That usually brings the piston flush with the cylinder. I don't mean to imply you have not tried this, I just don't know. Hope this may help.
2005 VN 750
Plexistar windshield
.040 pilot jets.
Splines lubed 1955 mi.
Iridium plugs
Reset pickup coil gaps.
Metzeler ME=880s
Shindengen MOSFET RR
V & H Cruzers
Degoated
Speed bleeders
MCCTs.
Bronson is offline
post #7 of 11 (permalink) Old 07-17-2010, 11:01 PM
I have not worked on brakes on my Vulcan, but have changed many disc brake pads on my cars. Like Bronson, I use a big C-clamp or special tool to push the piston back in. You may need to take the master cylinder cap off and remove some brake fluid to relieve hydralic lock.
post #8 of 11 (permalink) Old 07-18-2010, 12:14 PM Thread Starter
That was the ticket! I used a clamp and depressed the piston completely. Then I put the new pads back on and everything went smoothly. I rode it around the block and all seems well except for a sleight noise coming from what seems like the left caliper (when sitting on the bike). It's almost as if the pads are always in contact with the rotor, though it rides smoothly.
Should I be concerned? I think this sound was around with the old pads too, just not as loud. Perhaps it will pass?
Phil aka Art
"Vanessa"
26,440 miles
V&H Cruisers
Ear Shave
Rejet carbs
R/R relocate
HD Heritage seat
12" ape hangers
To Do:
Mirrors
post #9 of 11 (permalink) Old 07-18-2010, 01:39 PM
Brake pads do tend to lightly drag on the rotor all the time, in my experience.
If you changed to a different composition material in the pads you could get more noise too.
I think semi metalic or sintered metal may be noisier.
If the leading edge of the pads are not beveled off at 45* you can get a little squeeling noise at times too.
post #10 of 11 (permalink) Old 07-18-2010, 06:28 PM
If the caliper piston and cylinder are dirty and corroded it can cause the piston from working in and out freely.
I had this problem with my yammy and I had to clean both pistons and cylinders, but in my case the brakes had started to lock to where it would hold the bike back.
