steering wobble - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 06-21-2010, 05:39 PM Thread Starter
steering wobble
OK...spare me the lectures. I know I shouldn't do it, but we have all done it....
Pulling up to a stop or simply driving down the road, we take our hands off the handle grips. These bikes are well balanced and we can travel a fair distance without fear. That is unless you have a wobble.....like I do. Steady as a rock when both hands are on, but let go and the it starts to wobble almost uncontrollably. I have checked the obvious...rotors, stem locknut, etc. There is no play in the steering column at all. Tires are well balanced and free of defects.
Any other suggestions??
VoIPDoc is offline
post #2 of 9 (permalink) Old 06-21-2010, 08:02 PM
Yes, don't take your hands off the bars.
Do you have a windscreen of any kind? Handlebar mount screens can make a big effect.
How fast are you going when you do this?
Have you made any change to the chasis or suspension?
Lowering the bike, worn shocks , weak fork springs, low oil, or out of line wheels can cause a wobble.
post #3 of 9 (permalink) Old 06-21-2010, 08:44 PM Thread Starter
Do you have a windscreen of any kind? Handlebar mount screens can make a big effect. Does it with or with windscreen.
How fast are you going when you do this? <20mph
Have you made any change to the chassis or suspension? None...all stock
see comments above....
VoIPDoc is offline
post #4 of 9 (permalink) Old 06-22-2010, 11:20 AM
Undercover Sportbiker
AJCruzin's Avatar
Looks like you've checked all the usual suspects. It might be one of those things where it just happens. My ninjas, my Vulcan, and my VStar all did it, but only on specific road surfaces. On most others there was no visible vibration/wobble. It's happening a lot more frequently on my daily rider Ninja, but that's because I ran the tires with too little PSI and they're nicely cupped/scalloped.
AJCruzin is offline
post #5 of 9 (permalink) Old 06-22-2010, 01:13 PM
fergy's Avatar
Too little tire pressure can cause this too. Tires can look great but be a tiny bit out of balance and cause wobbling. Easiest thing to check is tire pressure. You probably want at least 36 in the front, near 40 in the back. I ran 36F and 42 back to make up for the cheeseburgers...
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #6 of 9 (permalink) Old 06-22-2010, 01:30 PM
I was just reading this thread about excessive vibration.
https://www.vn750.com/forum/showthread.php?t=15141
In post #11 lance mentions "steering stem spanner nuts". I am not sure if that is the same thing as the locknut you have checked or not.
post #7 of 9 (permalink) Old 06-22-2010, 07:06 PM
1985 VN-700
L2fish's Avatar
I bet the front tire is suspect. If you run your hand over it I bet its cupped.
L2fish is offline
post #8 of 9 (permalink) Old 06-22-2010, 09:43 PM
MANIC MECHANIC
vulcanjoe's Avatar
mine wobbled until i put the new tires on this year so go feel the tires
34k so far
VN750.com member #613
Keep the shiny side up
coastered
de-goat and baffles removed
jetted 42-150 2 shims
Earshaved with unifilters
inside of tank coated
spline lube
Shindengen FH012AA r/r
TPE stator
Saddlemen saddlebags
2001 HD fatboy solo seat
Fergy's coil relay mod
vulcanjoe is offline
post #9 of 9 (permalink) Old 06-22-2010, 10:02 PM Thread Starter
L2,
Was ready to take you up on the bet....no visible sign of wear or cupping. But rubbing hand over the tire and you can feel it.
Wanted some 110/90/19 ME880s anyway....just didn't think it would be this soon.
Thanks to all for the suggestions.
VoIPDoc is offline
