Front for rebuild? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 06-18-2010, 12:33 PM Thread Starter
TheBoy's Avatar
Send a message via AIM to TheBoy
Front for rebuild?
I have a front shock that is leakin!
I had a 2 inch lowering kit installed and all new seals put in but now its leaking. They are telling me that the inner shaft is pitted and thats why it leaking. But i know the right shock is completly blown because their is fluid running down the fork.
So im askin if i could buy new inner shafts and would they work? And does anyone have their front forks lowered? Because im not a big guy but i can feel my forks bottoming out sometimes, and i hear a big "CLUNK!" and was wondering if this is normal for lowered bikes. I know the travel is minimized but not sure if its suppose to bottom out that easily.
Some feed back would be nice guys, and money is tight after buyin the fluid and wet/dry seals... Im just a broke kid
TheBoy is offline
post #2 of 3 (permalink) Old 06-18-2010, 04:39 PM
The Professor
lance328's Avatar
Sounds like someone is feeding you some crap, they probably installed the oil seal incorrectly. BTW there is no inner shaft just the fork tube and slider. If pitting is the cause you should see it above the dust seal.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #3 of 3 (permalink) Old 06-18-2010, 05:04 PM
I lowered mine. I do get a bottoming out every once in a while. It does take a good bump for it to bottom out. But I did not install the extra small springs that came with the kit.
