180/70/15 fits!!!!!!!! - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 15 (permalink) Old 05-28-2010, 01:17 PM Thread Starter
BMan23777's Avatar
Mounted a 180/70/15 on grimm the other day no mods with clearence!!!!
ID:	2816   Click image for larger version
ID:	2817   Click image for larger version
ID:	2818   Click image for larger version
Brian Manchester
'89 "GRIMM"
04 durango AWD
BMan23777 is offline
post #2 of 15 (permalink) Old 05-28-2010, 02:06 PM
On His Lady Vulcan
wkrizan's Avatar
Good to know, thanks.
Pictures of the "Ladies"
wkrizan is offline
post #3 of 15 (permalink) Old 05-28-2010, 03:34 PM Thread Starter
BMan23777's Avatar
And the best part is the Tire was free!!!!!!!! Brand new with the tags still on it!!!!!
Brian Manchester
'89 "GRIMM"
04 durango AWD
post #4 of 15 (permalink) Old 05-28-2010, 04:00 PM
Check manufacturing date on tires.
I`m happy for your good luck in getting a free tire. I am wondering why it was free though? I am hoping it is not New Old Stock (NOS). Have you checked the manufacturing date code molded into the sidewall as part of the serial number. Here is some info I copied from another thread:
There'll also be a date code on the tire - baseline is you don't want to run a tire older than 5 years old.
There'll be a dot number on the tire - There should be 4 numbers at the end (assuming the tire is newer than 2000). 0900 would indicate the 9th week of 2000, 2304 would indicate the 23rd week of 2004, etc.
If the tire was manufactured in 99, etc the code will be a 3 digit code - 159 would be 15th week of 1999, 444 would be the 44th week of 1994, etc.
If you want more info, there is a video on youtube about some dangers of running old tires, even if they look brand new.
post #5 of 15 (permalink) Old 05-28-2010, 05:12 PM
baldy's Avatar
Someone that shares my appreciation of fat tires. haha I have a Dunlop 110/90-19 on front Dunlop 170/80-15 on back. It is real close to the shaft housing so yours must be real tight. Didn't see any 180s though. What make is it?
01' VN750
Jardine cross over exaust
Kyriakin grips and foot pegs
Modified seat and backrest
Luggage rack
Spline lube
93' VN750 getting TLC
Decals and mirrors
ACCTs to MCCTs
Degoated with Harley mufflers
Pick-up coils at .020
Spline lube
baldy is offline
post #6 of 15 (permalink) Old 05-29-2010, 01:35 AM Thread Starter
BMan23777's Avatar
Not NOS Hoss just happened to be at the rite place rite time!!! place was bought out and the guy that bought the stock is a friend and dosen't work on bikes and gave me the tire. And baldy there is a fingers width space between shaft,track bar,and brake bar. the make is pirelli modle route m66!!! Next will be the 110 in the front!!!
Brian Manchester
'89 "GRIMM"
04 durango AWD
post #7 of 15 (permalink) Old 05-29-2010, 07:20 PM
baldy's Avatar
My 01 has the Dunlop 404 170/80-15's and I can't put my pinky between the shaft cover or the brake bar. Maybe where yours is an 89' its got a bit more room?
01' VN750
Luggage rack
Spline lube
Decals and mirrors
ACCTs to MCCTs
Spline lube
baldy is offline
post #8 of 15 (permalink) Old 05-29-2010, 07:37 PM
IMBoring25's Avatar
Same-size tires from different manufacturers aren't necessarily the same size. Consider the following example of some real steamrollers of car tires rated as the same size from two different manufacturers:
http://forums.corral.net/forums/show....php?t=1051408
If the tires were mounted on different-size rims when the dimensions were determined, that might explain the difference. There's not much more than pinky clearance on my brake bar with the stock-size Bridgestone S11.
IMBoring25 is offline
post #9 of 15 (permalink) Old 05-29-2010, 07:43 PM Thread Starter
BMan23777's Avatar
Not sure why???? But know there is room there for tire expansion and just checked again and can get my index finger in there!!!! So like 3/8 to 1/2 inch clearance!!!
Brian Manchester
'89 "GRIMM"
04 durango AWD
post #10 of 15 (permalink) Old 05-30-2010, 07:08 PM
baldy's Avatar
Damn start looking for a 200 next time you need a tire. lol
01' VN750
Luggage rack
Spline lube
Decals and mirrors
ACCTs to MCCTs
Spline lube
baldy is offline
