Tire mileage - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 05-11-2010, 10:23 PM Thread Starter
Tire mileage
Does any one else here run the Dunlop 404 on the rear and if so what kind of mileage are you getting out of it and can you find the wear bars on it?
post #2 of 3 (permalink) Old 05-11-2010, 10:41 PM
MANIC MECHANIC
vulcanjoe's Avatar
I have the D404 for right now. It is 5 years old now I have maybe put 7-8k miles on it so far (had other bikes in between) Have not seen the wear bars yet but i will look tomorrow and measure tread.
34k so far
VN750.com member #613
Keep the shiny side up
coastered
de-goat and baffles removed
jetted 42-150 2 shims
Earshaved with unifilters
inside of tank coated
spline lube
Shindengen FH012AA r/r
TPE stator
Saddlemen saddlebags
2001 HD fatboy solo seat
Fergy's coil relay mod
vulcanjoe is offline
post #3 of 3 (permalink) Old 05-12-2010, 08:31 AM
GIMPYRDR's Avatar
Had the D404 on mine last year and got roughly 5-6k on the back tire. Probably could have got another 1-2k if not for a razor blade. Check the pic.
https://www.vn750.com/photopost/data/...030_edited.JPG
2005 Vulcan 750
Black and Silver
Saddlebags
OEM Hghwy Bars
O-ring Footpegs
OEM Luggage Rack
V&H Exhaust System
TOC ACCT Rebuild
Die Hard Gold AGM MFB
Spline Lube every tire change
VN750 #4393
VROC #31065
TexasVROC
GIMPYRDR is offline
