Steering stem bearings - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 05-05-2010, 02:32 PM Thread Starter
Question Steering stem bearings
Is there any way to lube the steering stem bearings without having to disassemble the gages, handle bars, and remove the fork?
RealDeal56 is offline
post #2 of 9 (permalink) Old 05-05-2010, 03:08 PM
I have not had the pleasure of having to lube mine yet, but from a look through the section in the Clymer manual pertaining to the head bearings, it appears everything you mentioned has to come off.
post #3 of 9 (permalink) Old 05-05-2010, 08:06 PM
actually all you need to do is remove the handlebar clamp to get to the top nut.
post #4 of 9 (permalink) Old 05-06-2010, 02:14 PM
OK, removing the top nut, washer etc. gets you to the top bearing.
It still appears to me that a lot more components have to be removed to get the steering stem out to get to the lower steering stem bearing.
Am I missing something here slim???
post #5 of 9 (permalink) Old 05-06-2010, 05:35 PM
ok so its a little more complicated than what I said, but not much, before removing the top nut, loosen the fork clamp bolts then remove the nut, once the nut is removed, the top clamp will be able to lift off, and the bottom clamp can then be slid down the forks.
post #6 of 9 (permalink) Old 05-25-2010, 10:05 PM Thread Starter
Thanks guys, I appreciate your help. Sorry I did not respone sooner I have been offline for a while. Thanks again.
post #7 of 9 (permalink) Old 05-26-2010, 02:26 AM
You need to remove a ton of stuff. Front wheel, fender, forks, brakes, handlebars, instrument panel, headlight, and a whole bunch of little parts. Going by the book here, I have never had mine apart, and see no reason to take them apart unless a problem shows up. Steering head bearings, just like swing arm bearings wear very slowly, they can be adjusted without removing all that stuff. Unless you've been using a high pressure washer, like a car wash, on the bike, the grease in there should be good for over 100,000 miles. If I ever do find a problem with mine that an adjustment won't fix, then and only then will I take them apart, and after going to all that trouble, I will certainly be installing new bearings.
Very few bikes have ever had their steering head apart. The manufacturer just puts that on the maintenance schedule because it is a labor intensive job, and they see $$$$. Jerry.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
post #8 of 9 (permalink) Old 05-27-2010, 06:53 PM
Once again your arrogance and ignorance precedes you... I just got done putting my bike back together... I disassembled it to the frame, short of an engine pull, to inspect the bearings on most of the harder to lube points... i.e. the steering head, swing arm, and wheel bearings. All I did was removed the cover for the handle bar risers, the handle bars, loosened up the tripple tree clamps, removed the top nut, slid off the upper tripple tree and slid down the lower tripple tree. I left the fend intact and the front wheel intact. Once I saw how dry my steering head bearings were, I decided to pull the front wheel bearing as well to lube them... the forks never left the bike. The book doesn't t3ell you all the shortcuts to removing everything... like you said they tack on extra stuff into the manuals so that the shops can charge more labor.
post #9 of 9 (permalink) Old 05-30-2010, 03:49 PM
Like I said, I went by the book, and have never done this with a Vulcan 750. I doubt a dealer would do all that either, but they would probably charge you for it. I would probably do even more than that on my own bike, I am very meticulous when it comes to my own vehicles. I just can't see any reason to do it at the moment. At 45,000 miles the steering stem is tight, but turns freely, there is no binding, I don't use high pressure water on it, and it doesn't often get ridden in the rain. I'll just keep checking it, and when I do find a problem that adjusting the bearings doesn't fix, I'll tear into it as soon as I have the time. There is nothing in there that could cause a catastrophic failure, it would wear slowly. Jerry.
1979 Vespa P200E
