Vibration in turns - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 05-04-2010, 01:01 AM Thread Starter
Unhappy Vibration in turns
I would like to explain whats going on with my bike and see if any one else has ever experienced this .
As I lean into a turn ,right or left,I get a small buzzing vibration all over the bike ,nothing major just annoying,It feels like a rough wheel bearing ,But up on the stand spinning the wheel s front or rear I cannot feel it,maybe it is because it is upright and not side loaded that I cannot feel any roughness in the bearings.
I have checked both tires for cupping and unusual wear and find no problem,the rear tire is worn some but not anything like worn out,I am sure the front is too but it isn't showing as much as the back one and they were installed as a set about 8000 miles ago, No problem in a straight line just a little aggravation in the turns,I suspect the back tire is feathered a little that I can't see or feel or a bearing that gives a little under a side load and is worn some I guess I need to start taking bearings out and check them one at a time for roughness and slack,It is possible they are oem since I have never changed them,Any body else got any thing I should check?I might add that the handling has not been adversely affected either.
post #2 of 6 (permalink) Old 05-04-2010, 01:15 AM
MANIC MECHANIC
vulcanjoe's Avatar
my bike did this right after i got it i took a shot at the front wheel bearings first i got lucky and that was it.
34k so far
VN750.com member #613
Keep the shiny side up
coastered
de-goat and baffles removed
jetted 42-150 2 shims
Earshaved with unifilters
inside of tank coated
spline lube
Shindengen FH012AA r/r
TPE stator
Saddlemen saddlebags
2001 HD fatboy solo seat
Fergy's coil relay mod
vulcanjoe is offline
post #3 of 6 (permalink) Old 05-04-2010, 01:24 AM Thread Starter
I put them first on the list to check then, were yours worn or loose feelling or did you just replace them?
post #4 of 6 (permalink) Old 05-04-2010, 02:18 AM
The Professor
lance328's Avatar
Check wheel bearings, stering stem spanner nuts and upper tree bolt.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #5 of 6 (permalink) Old 05-04-2010, 02:56 AM Thread Starter
Thanks
post #6 of 6 (permalink) Old 05-04-2010, 09:19 AM
MANIC MECHANIC
vulcanjoe's Avatar
mine felt good on the bike but when i took the wheel off there was a little side to side play
34k so far
coastered
spline lube
TPE stator
